How 2 change default O/P of 1+2 of PLAY SELECTION cmd to 3+4
vpg
Post by vpg »
Hey there,
Having a memory lapse here and hope you guys can help out...
How do I change the default output when monitoring audio using the "play selection" command?
Right now, when I use the "play selection" command in the sequencer window (you know, after I double click on an audio file and then click and drag over the selection of audio I want to hear, and then hold down Command+Space bar to hear that selection of audio play back), it defaults to outputs 1 & 2 (which for most of my work situations, is cool.) However, right now, I want the default output to be 3 & 4 when using the "play selection" command. Is this possible? If so, where's the shortcut or command to make this change from 1 & 2 to 3 & 4?
thnx in advance ~
Li (sounds like "Lee")
Dwetmaster
Re: How 2 change default O/P of 1+2 of PLAY SELECTION cmd to
Post by Dwetmaster »
It'll default to whatever is at the top on your bundle output list.
