Mach 5 v3 with FL Studio 10?
Is there anyone that is using Mach 5 v3 or had used Mach 5 v2 with FL Studio? I'm looking in to buying this product, but I've read that version 2 didn't play well with FL Studio and was a big cpu hog. If someone has any input on this before I make this purchase I'd really be thankful for that. I should add that if I do buy Mach 5 I am pretty much getting it just to use the sound library. Is there any way I can configure it to be less intensive on CPU if I'm using it only for sounds and not the rest of it's functions?
Re: Mach 5 v3 with FL Studio 10?
AFAIK there is no issue.
You can check with UVIWorkstation as there as based on the same engine to know for sure.
HTH
HTH
