The MachFive 3 REVIEW-1: the Good, the Bad, & the Ugly
These are only initial observations from just running thru the patches (all the patches) very quickly and not really spending much time in the interface at all.
First the good:
A lot of sounds - and a lot of them useful for all sorts of settings. Even with 2 DVD drives, it took quite a while to load all the discs. Some of the arpeggiations were really fun to play around with and I could see them being very useful in the right musical environment. Some of the legato tricks (like slurring and gliding between notes when the previous key is held) provide a realistic performance. These are most interesting (at first listen) on the acoustic bass and woodwinds. For my purposes, I'd probably get use out of maybe 40-50% of the sounds over the lifetime of the app (or the user).
MachFive-1 and -2 presets loaded right in as did the UVI and Kontakt presets. The newer version of Garritan (Aria Player) did not and neither did the Miroslav Phil CE presets. Not really a big loss. My M5 1 & 2 libraries are quite extensive and I've customized a lot of sounds for design. It is very comforting to know these just drop in and I don't have to do anything. It's also nice to know there are fantastic tools to make them even better now. Not unexpectedly, none of the Korg legacy presets would load either. Again, no big loss as they are simple enough to load from their native apps.
...and the bad:
Not so bad really. With DP hosting it, DP will remember the last loaded M5 patch (as long as you save the project but there is no warning that you changed a patch so if you don't save and change a patch the last saved project patch will appear). If you change or tweak the M5 patch and quit or close the project, there is no warning that the changes will be lost - and they will be lost. Perhaps there is a preference for that - I couldn't find it. Even something as simple as changing the overall volume or pan setting from within M5-3 will be forgotten, at least by the M5 plug-in.
In stand alone that is not the case. Make a change and the standalone version will warn you to save or discard the changes. I can't imagine that is a useful nor intended implementation. You do have the option to save changes to a new user preset, but not everyone remembers to do that and if you're like me, you instinctively hit CMD-s, CMD-q, grab your coffee and rush out the door. It would be nice if M5-3 would at least warn you that you have unsaved changes.
Interestingly, in Plogue Bidule, that app does remember changes to M5-3. It doesn't ask you to save them, but PB saves them. You'd think DP would as well, but no!
The factory patches I liked, I liked very much - some of the others... not so much. I was hoping for a better orchestral library and while it's not terrible, well... I guess I'm just spoiled. I'll just spring for the LA Scoring Strings and shut my face on that one. Then again, I have not tweaked ANYTHING yet so it may be that the presets can be massaged into a more useful sounds. There are certainly a lot of samples and the potential to adjust them to one's taste is clearly there, so I may be overly harsh in this regard. Out of the box, I'd probably not use too many of the pitched orchestral sounds on a regular basis. Percussion is excellent and the shakuhachi #2 is really a delight.
...now the Ugly:
Not Lady Gaga butt ugly, but bad enough. More than a few patches could not find their samples. I probably ran into maybe 4 or 5 that would not load and returned errors. Also, some of the presets were just a waste of space, IMO. Really useless for any purpose I could imagine. I already had the ExtremeFX package so I didn't load that from the MOTU DVDs. I did load the UVI version and it went right in. No sense in duplicating it and going thru the licensing thing again.
So once again, as they used to say on American Bandstand - 'I'll give it a 90.' I have NO REGRETS in purchasing the upgrade and can't wait to play with the totally awesome (in the truest sense of the word) processing. The online videos James mentioned only scratch the surface, but are great to get a sense of the power and interface. M5-3 is not completely the 'universal' end all sampler, but it's no dog and considering that I'd only use half the sounds, that is still a damn lot o' sounds.
Now if MOTU doesn't wait 2 or 3 years to update the plug in so it works like the standalone when it comes to reminding the user about unsaved changes (and not loose track of even a few samples) that would be a very good thing.
OK... I'm done.
Oh yeah, I still need to...
:rtfm:
About 250 pages and at first glance, I really need to...
:rtfmmad:
ps- Save and lost samples reported to MOTU as a Techlink.
Last edited by MIDI Life Crisis on Tue Sep 20, 2011 7:44 am, edited 2 times in total.
twistedtom
Re: The MachFive 3 REVIEW-1: the Good, the Bad, & the Ugly
Post by twistedtom »
Thanks Shoo; ordered it today.
I know Shoo and I'm no Shoo. But I did stay at a Holiday Inn last night. :)
FutureLegends
Post by FutureLegends »
Thanks for the report... now if I could only find those missing $179 (+$79 postage to sweden) so I can order my upgrade... ;-)
twistedtom
Oh sorry MLC, I must have been off in space some place. :oops:
Not really. Usually it's the Shooshmeister who writes extended, informative posts. I won't make a hobbit of it. :)
Buzzy
Post by Buzzy »
MLC I've just gotta give you kudos for using both :rtfm: & :rtfmmad: in the same post.
Oh Yeah! :koolaid:
.Bzz...
Mac Pro 6 Core-10.14.6-32GB | DP 10 | 828mkII fw | Receptor 1&2 |Reason 10.2 | Goliath | EWQLSO Gold | QL RA | Voices of Passion | Ocean Way Drums Platinum | SSD-EX | Chris Hein Horns 1&2 | Komplete 12 | AAS - Ultra Analog | BS Accordions | Nomad Factory Integral Bundle | WaveArts Power Suite 5 | Izotope Music Production 3 | Variax 600| TD-8 Drums ||STUDIO››|| MacPro QuadCore-2.66-10.4.11-8GB | 828mk3 fw | 8Pre fw (X2)| MC Mix (X3) MC Control ||
Much appreciated, but save the kudos for when I actually...
twistedtom
I loved that movie.
It may be a week before I get my copy of M5-3, oh boy wow. :band:
zandurian
Post by zandurian »
Thanks for the info
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
stephentayler
Post by stephentayler »
I can confirm MLC's save problem. After loading a new patch in M5-3 DP does not offer the option to Save, at least not until some other aspect has been changed. Do a tiny fader tweak, then DP will allow the Save, and then M5's settings are saved with the file.
Otherwise, apart from an issue with one of the Xtreme FX discs, all seems great. I think I am going to love this version.......
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Michael Canavan
Post by Michael Canavan »
Owners of MachFive 3 a few questions if you will. :)
The Xpander filters, are they gods gift or not? I actually have an Oberheim Xpander and love the fiilters, would be nice to use something equivalent in a DAW.
..and can you use M5-3 as an FX rack like you can with Kontact and Absynth etc. from NI?
The granular synth looks really really freaking nice! Have any of you tried it on your own material?
How much more of a CPU pig is M5-3 compared to Kontact?
I'm supposed to save money for the winter when work gets slow, but I really like the direction I see MOTU/UVI taking M5-3! :headbang:
gaucho
Post by gaucho »
can one of you early users try a gigastudio patch with modwheel crossfades, such as sonic implants french horns MW Xfade.
I am DYING to hear how it opens in the new version. Will the controllers work?
anamorphic
Post by anamorphic »
Can you elaborate on how M3 handles M2 instances?
Should I keep M2 installed for older projects or just use M3 and load M2 samples?
Mac Pro (2019) 3.2 Ghz 16 Core Intel Xeon W; 128 GB Ram OS 11.2 - DP10.13
MACHFIVE3, MOTU SYMPHONIC INSTRUMENTS, STYLUS RMX, TRILLIAN
MOTU MTP A/V, MOTU 828mk3, AVID Artist Mix,
YAMAHA 01V96i, PRESONUS Central Station, 2xJBL 3MKII, 5xTANNOY 6.5
ROLAND VS880, KURZWEIL PC88mx, KURZWEIL Artis SE, SHURE KSM44, Various Sound Modules
It just loads them the way they are in my ver 2 patch. I don't do a lot of fancy key mapping, but you can always keep ver 2 on the HD until you check out ver 3.
