OS X Lion
soniq2
OS X Lion
Post by soniq2 »
I'm currently running DP 6.03.
I'd like to upgrade to OS X Lion but need to upgrade to DP 7.24 to do this but don't believe I can upgrade directly from 6.03 to 7.24.
I see that there are versions 7.0, 7.1 and 7.2 available. Do I need to upgrade to 7.0 then 7.1 and then 7.2 or can I just upgrade directly to 7.2 before upgrading to 7.24?
-Mike
Re: OS X Lion
Get the paid update from MOTU and the current update will probably be on the disk. If not, just the current update is needed but the install from the DVD is critical as a first step.
MS Office drove me crazy with having to do the incremental updates. Increment is the new excrement! lol
jloeb
Re: OS X Lion
Post by jloeb »
MIDI Life Crisis wrote:Increment is the new excrement!
That's good. Oh that's good. I'm stealing that... :headbang:
FutureLegends
Re: OS X Lion
Post by FutureLegends »
Yes, you'll probably get 7.2x on DVD and might just have to upgrade to 7.24 after that. Maybe you'll even get the latest. So don't let those worries hold you back. DP7 is SOOOO much better than DP6!
Just make sure any other software apps you are dependent on are compatible with Lion before upgrading. In my case the only ones I'm really dependant on are DP, UAD, PLAY and EZDrummer. Of those UAD still isn't compatible and EZDrummer (the least important) I don't know the state of. Once UAD is compatible I'm getting a Magic TrackPad and uprade to Lion.
Iron, Lion, Zion!
barreltone
Re: OS X Lion
Post by barreltone »
Yep, I got the DP 7 upgrade a couple of months ago, and 7.23 was on the disk.
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
