EXPERIENCING WEIRD CRASHES OF DP7
sergiococchi
Post by sergiococchi »
Hi There!
I'm having a project that crashes wayyy tooo often,like when i edit a MIDI note or other stupid things.
I have only one Instance of MSI, one of Electric keys, and a Kontact Player with just a couple of instrum and very few plugins open(3 Ik CSR reverbs, 1 maserati, one T racks Comp, 1 wha pedal,1 waves Enigma, 1 DP tremolo,1 Live room)
I recently moved the NI (i.e Kontact) libraries from my system disk to the external disk where i keep my VI libraries( which i use for that sole purpose, firewire 800) , but opening other projects with Kontact plug in operating doesn't give me any troubles.
Could t be that project is somehow corrupted?
That' would be a bummer cause i spent a whole afternoon working on it...
Thanks in advance!!
Sjo
SirJo (aka SergioCocchi)
http://www.sergiococchi.net" onclick="window.open(this.href);return false;
http://www.foundactionmusic.com" onclick="window.open(this.href);return false;
powerbook pro 2.66ghz i7, 8GB, Traveler Mk1, Reason 6, MSI, MachFive 2, MX4, BPM,Electric Keys,Ethno 2, KOMPLETE 7 Players, IK T rax 3 Del, IK CSR Cl.Rev, Waves Maserati, ISA 220 A/D.
Elio
Re: EXPERIENCING WEIRD CRASHES OF DP7
Post by Elio »
Ciao quale versione di DP usi? ho avuto gli stessi problemi con la 7.21,con la 7.22 sono scomparsi.
When you say "moved", how so? Did you just move the files or run the installer specifying the other drive?
It could be something as simple as a corrupt directory - something is not finding something else.
My first thought is to re-run the installer if you just moved the files.
Try Disk Utility. If that is clean, try rebuilding your directory with TechTool or DiskWarrior.
sergiococchi
Hi! Thanks for the response!
@ Elio: era su 7.22, ora c'è 7.23 vedremo...
@ mikehalloran: I created an alias on my system disk after i placed the libraries on the external disk where i have all the other libraries.
I'll try what u suggested. THanks
