Two MIDI Express XTs with a RS-422 cable
Posted: Sat May 21, 2011 11:58 pm
by mrdelurk
I read somewhere that it is possible to hook up two MIDI Express XT's via RS-422 to create a MIDI hub with 16 ports. Well, I have two MIDI Express XT's (one USB and one USB-less), so I bought the RS-422 cable, plugged it into both XT's, and - got nothing. The USB powered RS-422 shows up all right in Clockworks and Ableton Live, but the second unit's additional channels are nowhere to be seen. Am I doing something wrong, does this connection require some advanced steps, or is it simply not possible to connect two units this way for a 16 port in/out system? Thank you
I posted this question on on MOTU Tech Support, received nary a reply in 2 months, I guess I managed to stump MOTU. :-)
Re: Two MIDI Express XTs with a RS-422 cable
Posted: Sun May 22, 2011 4:50 am
by SmilesLots
Check your manual. I have two networked MTP's and they work fine. But you will probably have to change some settings. I have neither the Express XT nor a manual, but if it can really be done, I'll bet it's in ghe manual, maybe under networking. God]od luck.
Posted: Sun Apr 27, 2025 7:45 am
by Braindead
Do you did the network with 2 motu MIDI express xt// ????
I try to did it , and it’s look impossible , but i read somwhere it was ok to did it......
I’m totaly lost with this matter and the manuel didn’t help for networcking 2 unit under windows
I own win 7
Posted: Sun Apr 27, 2025 9:43 pm
by monkey man
Braindead wrote: Sun Apr 27, 2025 7:45 am I’m totaly lost with this matter and the manuel didn’t help
Hey, I wouldn't blame Manuel; he tries his best, and... he learn..
Manuel from Fawlty Towers - But I Learn.gif (401.14 KiB) Viewed 430 times
Posted: Sun Apr 27, 2025 10:15 pm
by mikehalloran
Braindead wrote: Sun Apr 27, 2025 7:45 am Do you did the network with 2 motu MIDI express xt// ????
I own win 7
This is an old thread. The MIDI Express XT that was being made in 2011 is not the current model.
