Help identifying old MOTU hardware
electrickoho
Post by electrickoho »
Hi All,
I am trying to sell this old MOTU MIDI Timepiece, but I haven't been able to identify the product. Can you please help me identify this product, and determine it's value (if it has any?).
Thanks.
SmilesLots
Re: Help identifying old MOTU hardware
Post by SmilesLots »
Could you post a clear picture of the rear panel and the bottom panel?
Mac Pro 1.1, SL 10.6.8, 13 gigs ram, DP7, 2 MTP-AV-USB, MTP-AV serial, Microlite, 828mk2, 828mk3, HDX-SDI, 7 other Macs
electrickoho
Here's a picture of the back
Here's a picture of the bottom label
stephentayler
Post by stephentayler »
possibly some info here??
http://www.cassiel.com/space/Gearhead/M ... Time+Piece" onclick="window.open(this.href);return false;
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
buzzsmith
Post by buzzsmith »
Pretty sure that this is the original MOTU MIDI Time Piece.
On eBay, about 25.00 in non-working condition...
http://cgi.ebay.com/Mark-Unicorn-MIDI-T ... 483e73b698
Buzzy
(I have 2 lying around somewhere!)
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
aoresteen
Post by aoresteen »
AFAICR This was a Mac unit. There *MIGHT* have been an ISA card for it.
It *should* work with OS8 and OS9. I have the MIDI Timepiece II and I'm trying to get it to run on my 68000 Mac using OS 8.1. Clockworks boots but I need to load FreeMidi but it's bigger than a floppy.
Heck, it just might work with 7.5.5.
Here's the OS9 driver for it:
http://www.motu.com/download/download_m ... duct_id=16" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
MOTU does not have a serial OSX driver for it.
You will need a 9VDC power adapter for it and a Mac 8 pin DIN serial cable "MacPlus" type.
Good luck!
Word up-- you can use this with OSX. You will however need a USB MIDI Time Piece and you can then daisy chain this old unit off the newer one with the right serial cable.
johnrule
Post by johnrule »
I just resurrected this beast myself...it is indeed the original MTP. I am using it on OS9 with a G4 (using gPort for the serial) and OMS to communicate to my Oasys PCI. I wanted to add a PolyEvolver rack to my setup, so I decided that my old MIDI matrix should do the trick...it still works fine! I believe I had it setup for OSX at one point as well, you just need the gPort MIDI driver or something.
However, there are a few tricks to getting this to work (at least for me):
- You need the old version of MTP Console (MTP II Console 1.04) if you want to avoid FreeMidi.
- You may need to connect to the Network port first to be able to establish communications.
- The memory battery is probably no good, so you will lose your settings if you unplug the AC adapter (although you can turn it on/off on the front fine).
The power supply is 9VDC, 500 ma, center positive.
There used to be modification instructions somewhere for replacing the memory capacitor, but I cannot seem to locate them.
Does anyone know which capacitor to replace or have those instructions?
Thanks,
JR
