MIDI Express XT Routing
themagichoof
Post by themagichoof »
Can you change the routing on the MIDI Express XT via the front panel, or is all of this done strictly via software? And is there a difference between the older serial version and USB version as far as changing everything from the front panel? I was thinking maybe that it was necessary to program everything in software via the serial port or usb connection and THEN you can use it as a standalone. But it would be nice if you can do it both ways.
