MIDI Command for Monitor Level?
ioplex
Post by ioplex »
Some CueMix FX functions can be controlled using a Mackie compatible control surface. But I have only seen the faders and solo toggles work using MIDI. Does anyone know of a MIDI event that can control the Monitor Level at the upper right of CueMix?
I tried to use MidiPipe to change the Pitch Wheel channel. For example I successfully controlled the second fader (channel 2) in CueMix using the first fader (channel 1) on the control surface. Then I tried channels 10 through 16 but it had no effect on anything near as I could tell.
[I know the Master Vol encoder on the front panel of some MOTU audio interface units like the 828 and Traveler control the Monitor Level but it's a little hard to use. It's small and slippery and buried among other identical knobs.]
siepino
Re: MIDI Command for Monitor Level?
Post by siepino »
almost my same request.......
http://www.motunation.com/forum/viewtop ... =2&t=43051" onclick="window.open(this.href);return false;
:shake:
