V.I. and MIDI track
dado
V.I. and MIDI track
Post by dado »
Hello everybody, this is a stupid question I know, but I would like to know why in DP to open a V.I. I need to open two tracks, one for MIDI and one for V.I. I must know because I told to a friend of mine to jump on DP. He work on LogicPro and told me he don't need to open two separate tracks for MIDI and VI. Thanks to everybody
iMac 27" 3 ghz 32 Giga ram / DP 11 / Motu UltraLite mK4/ TLAudio Ivory 5051 / Addictive Drum2 / PRS Custom22 Guitar / Boss Katana100 / Line 6 Variax700 / Strat by Tino Tedesco
FMiguelez
Re: V.I. and MIDI track
Post by FMiguelez »
I don't think it's a big deal...
Besides, this allows for more flexibility, as far as I'm concerned. It's just DP's way of working, and it makes PERFECT SENSE.
Show your L friend all the things you can do with DP. He will turn green with envy like this: :mrgreen: , but not with a stupid smile.
Besides, if for some strange reason this would be a deal-killer for you, you can always use Clippings or use templates, so you don't even have to create any new tracks. Just take the time to set them up the way you like, and watch how by dragging and dropping (not that dropping) you get whatever you put in the clipping back in your session in under 2 seconds, everything pre-configured and routed.
With this, your L friend will not turn green but more like purple with envy :boohoo:
More specifically, it is a MIDI channel per track.
828x MacOS 14.7.6 M1 Studio Max 1TB 64G DP11.34
jloeb
Post by jloeb »
By keeping instrument tracks separate from MIDI tracks, MIDI is more flexible and inuitive to deal with. You can use different MIDI tracks, each with different MIDI plugins such as arpeggiators, MIDI effect, controller reassignments, etc to drive the same or overlapping sets of VIs, and it all shows up clearly right on your mixing board.
And by the way, MIDI tracks are in reality different entities from the instruments they drive, so it's a conceptually cleaner and more accurate representation of the way things really work. That allows you to get fancier with routing while keeping things clear and organized.
noah330
Post by noah330 »
This is a good thing.
Last night I was recording a part with B4II.
I decided I didn't really know if the organ was right so I added an Electric Keys EP and just assigned the MIDI channel to it.
I do this all the time.
Kubi
Post by Kubi »
Agreed, it's most definitely a strength, not a weakness.
Just ask your friend to show you how he runs a multi-timbral VI in Logic, he he he...
:dance:
DP keeps a continuity between external hardware and internal VI's, so that they appear and are accessed in the same way. The instrument "track" is a place -- a tangible thing or virtual instrument -- which you can see and associate with the instrument(s) you want to create and use. You can assign as many MIDI tracks as you want to the VI's MIDI channels.
Most multi-timbral VIs allow you to assign either all instruments to one audio output, or assign each to its own audio track. Again, this is consistent with the way MIDI gear generally works if it has multiple outputs.
You can put ALL your instruments into a V-Rack if you like. I find this to be so easy and convenient that other methods seem silly to me now. But if you're new to it, I'm sure it feels awkward at first. Just think in terms of actual hardware with its own MIDI input and audio outputs.
