Slate FG-X 1.1.2 update available, working on PPC/Tiger
Posted: Mon Aug 16, 2010 9:09 am
Slate finally fixed the issues with PPC/Tiger and their FG-X mastering
plug-in, so I took the plunge and bought it this morning. It's working
fine in Peak on my PPC Dual 2.3/Tiger. It's too much of a CPU hog to run
in DP on a project that has..well, more than one stereo track. Intel
Mac users will be fine.
I have to say, this is an absolutely brilliant plug-in...unlike every
other maximizer I own (including Ozone4), the drums don't get knocked
back into the mix when the output gain is cranked up. I'm able to
get a master as loud as my loudest CD reference tracks without losing
the transient detail. I'm doing a heavy industrial/pop project with
a female vocalist, and she's always complaining that the masters just
aren't loud enough. FG-X to the rescue.
The 1.1.2 update includes three sets of meters (an input VU, and output VU,
and a set of LED meters which display Peak and RMS levels simultaneously).
There is a bus compressor section before the level (limiting) section, so
you can use it as a bus compressor as well. I found that I didn't really
need the bus compressor on, but it's there if you want to add that bus
compressor "glue".
I made a mastering chain in Peak with Ozone4 on the first slot, with the
EQ, multiband comp, and exciter engaged, and then followed that with FG-X
on the second slot, and my CPU usage was about 65%. It made for a nice
combination. Slate states in the manual that RMS levels less than -7.0 from
0dbfs will likely introduce distortion, and I found that this was true.
At -7.0 RMS, the master will be insanely loud anyway.
I recommend FG-X, if you're looking for something to make your masters
the loudest masters on earth without losing transients or adding a lot of
distortion.
compressor "glue".
distortion.
