Slate FG-X 1.1.2 update available, working on PPC/Tiger
David Polich
Post by David Polich »
Slate finally fixed the issues with PPC/Tiger and their FG-X mastering
plug-in, so I took the plunge and bought it this morning. It's working
fine in Peak on my PPC Dual 2.3/Tiger. It's too much of a CPU hog to run
in DP on a project that has..well, more than one stereo track. Intel
Mac users will be fine.
I have to say, this is an absolutely brilliant plug-in...unlike every
other maximizer I own (including Ozone4), the drums don't get knocked
back into the mix when the output gain is cranked up. I'm able to
get a master as loud as my loudest CD reference tracks without losing
the transient detail. I'm doing a heavy industrial/pop project with
a female vocalist, and she's always complaining that the masters just
aren't loud enough. FG-X to the rescue.
The 1.1.2 update includes three sets of meters (an input VU, and output VU,
and a set of LED meters which display Peak and RMS levels simultaneously).
There is a bus compressor section before the level (limiting) section, so
you can use it as a bus compressor as well. I found that I didn't really
need the bus compressor on, but it's there if you want to add that bus
compressor "glue".
I made a mastering chain in Peak with Ozone4 on the first slot, with the
EQ, multiband comp, and exciter engaged, and then followed that with FG-X
on the second slot, and my CPU usage was about 65%. It made for a nice
combination. Slate states in the manual that RMS levels less than -7.0 from
0dbfs will likely introduce distortion, and I found that this was true.
At -7.0 RMS, the master will be insanely loud anyway.
I recommend FG-X, if you're looking for something to make your masters
the loudest masters on earth without losing transients or adding a lot of
distortion.
http://www.davepolich.com
mhschmieder
Re: Slate FG-X 1.1.2 update available, working on PPC/Tiger
Post by mhschmieder »
Based on Dave's feedback, I am hoping to download and try the demo tonight, for an instrumental Heavy Metal piece that I MUST finish producing tonight! :shock:
In case I forgot to mention this elsewhere, I found out recently that Slate Digital is a cooperative venture with Fabrice of Eiosis. This gives me great confidence that Slate Digital will deliver great-sounding products that are well-thought out in their workflow and GUI design.
I don't know yet whether Fabrice is porting over some of his Air EQ algorithms or his E2 Transienter as part of the Slate Digital technology pool or not -- just that it was announced earlier that this is a partnership between these developers.
Dunc
Post by Dunc »
I downloaded the latest update as well and DP is still not seeing the AU version (nor is Peak)
I can however load the VST version in Peak. (Boy what a processor hog) So it looks like even
if DP did recognize the AU, I wouldn't be able to run a full mix with it anyway.
My system is a G5 PPC x2 running 10.5.8 w/4 gigs ram.
Having said all that this FG-X plug is looking like it might be a winner
Dunc
David Polich
Dunc wrote:I downloaded the latest update as well and DP is still not seeing the AU version (nor is Peak)
Dunc
Did you try deleting your AU Info Cache and letting DP re-scan your plug-ins? It should show up after that..it shows up in DP here on my system.
As you said, not that it would matter in DP on your system - FG-X will overwhelm DP on a G5 for sure.
Dunc
Post by Dunc »
Hi David
No I didn't delete my AU info cache. I've resigned myself to the fact it won't run in DP with my current configuration. I'm just happy I can open it in Peak and accomplish what I need to do in there.
Dunc
