Page 1 of 27
Suggestions for next DP update
Posted: Thu Jun 24, 2010 10:12 am
by chaim
• What's possible with Option A (audio assignments) regarding audio tracks, should be possible for MIDI tracks and sends as well.
• my long time request, a solo button in the SE, by each track.
Re: Suggestions for next DP update
Posted: Thu Jun 24, 2010 10:53 am
by Tesionman
chaim wrote: • my long time request, a solo button in the SE, by each track.
Agreed!
Posted: Thu Jun 24, 2010 2:42 pm
by grouse
Agreed!
Agreed +1.
Posted: Thu Jun 24, 2010 4:23 pm
by kassonica
Tab to transient has been on the top of my list for a long time.
Posted: Fri Jun 25, 2010 2:06 am
by Shooshie
Comping MIDI tracks would be nice. Especially if it were "smart" so as to finish open-ended controllers if other controller of the same type do not follow. (Sustain pedals, for instance.)
Posted: Fri Jun 25, 2010 4:27 am
by chaim
• mute MIDI notes
• a quicker way to pencil in, different CCs one after the other.
(like if you pencil in a MIDI track an adjustment on expression, then you want a little adjustment on the modulation etc... it becomes sort of a pain to have go through the mebus and select.) If you need to do this very often, you'll perfectly understand my point. 8)
Posted: Fri Jun 25, 2010 4:36 am
by Tesionman
ohhh hell yesss! Definitely Tab to transient and Muting MIDI notes(individual notes in MidiEd and whole blocks in TrackOv)!
Posted: Fri Jun 25, 2010 4:37 am
by newrigel
Just highlight and delete... then ⌘Z he he. There's your MIDI note mute.
Posted: Fri Jun 25, 2010 1:18 pm
by shaman
It would be useful these features:
- Go To Next/Previous frame.
- Set Region Start/Sync Point/End to playhead.
- Play movie in fullscreen on secondary monitor.
- Movie follow nudge edition.
Posted: Fri Jun 25, 2010 1:47 pm
by daniel.sneed
A preference choice between different pan laws :
center -3 dB (I won't have any use of this one, I guess)
center -4.5 (actual DP pan law, AFAICR)
center -6 dB (this one would fit most of my projects)
BTW, I've already sent this suggestion to Motu.
Posted: Fri Jun 25, 2010 3:14 pm
by FMiguelez
chaim wrote:• mute MIDI notes
If you click on any controller point in the SE, you will instantly be able to edit it.
Especially nice if you are working in Lines mode.
Posted: Fri Jun 25, 2010 3:58 pm
by ccrane
Such a simple, tremendously useful function.
God bless 'em, but I just don't think MOTU gets it - I mean, 7 versions in and no solo in SE? :shock:
Posted: Fri Jun 25, 2010 4:46 pm
by James Steele
No... obviously they're totally and utterly clueless.
Posted: Fri Jun 25, 2010 4:49 pm
by cbergm7210
+ Me
Posted: Fri Jun 25, 2010 5:30 pm
by James Steele
As an alternative option, I'm pretty sure you can use a keyboard shortcut to engage Solo Mode, and then you can click the play enable buttons to designate which tracks are soloed or even option click the play button of one particular track to solo just that track.
