An Old CD Issue
- adriano
An Old CD Issue
Hello forum.
I have an old CD with a couple of songs on it, that I backed-up to it about 12 years ago.
The bottom of the CD has no scratches at all, but the matte (label side) has flaked off taking the shine you'd see when you flip the CD, away.
I believe this is causing the CD not to be read anymore. Is there a way that I can fix this?
Any suggestions are appreciated.
Thank you,
Adriano
Thank you,
Adriano
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
Re: An Old CD Issue
Moving to General Recording I guess. This is not a Digital Performer issue.
- buzzsmith
Re: An Old CD Issue
Shooting in the dark, here...adriano wrote:Hello forum.
Thank you,
Adriano
1. If you hold the CD up to a strong light, and look through it, do you see any abnormalities or surface wear?
As you well know, the data is recorded in the colored coating on the non label side. There should be no defects in that layer, at all.
The top side "should" make no difference unless a torn paper label is somehow jamming the CD player mechanism.
2. Have you tried various CD players or different computers? I've had severely damaged discs come in that the Mac would not mount, but a 10 year old Sony player would read.
3. Is the disc really clean?
I think that's all I've got!
For some probably useless info...
http://en.wikipedia.org/wiki/CD-R
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- bkshepard
Re: An Old CD Issue
Buzzy's right, try it in some different CD players. If all else fails, try putting one of the CD-Stomper type labels on the label side. That may help to restore the reflectivity to the disk and make it readable again. Good luck!
-Brian
Mac M1 Ultra 20-core, OS 14.6.1, 128 GB RAM, DP 11.3.2, UA Apollo x6
- adriano
Re: An Old CD Issue
Sorry James. I really didn't know where to place the thread.
Hi Buzzsmith.
Yes, the CD has no scratches and it's clean. What happened is that the matte has flaked off removing the shine along with it and the CD looks like plaxyglass now.
I tried it in 5 other CD players and two of them will play it for about 6-7 seconds and then it stops.
I will try bkshepard's suggestion too. I think the reflectivity (the shine) it's the problem.
Buzzsmith and bkshepard, thank you
Adriano
Hi Buzzsmith.
Adriano
Re: An Old CD Issue
Sounds like the plastic laminate may have separated allowing the aluminum layer to oxidize. I can't think of any way to restore the aluminum layer. I hate to say it, but I think the CD is hosed.
- kassonica
Re: An Old CD Issue
A real LONG LONG SHOT
Put it in the fridge over night, let it thaw and see if it works.
Re: An Old CD Issue
That CD is a goner. Faggedaboudit.
http://www.davepolich.com
- adriano
Re: An Old CD Issue
Yeap. It's a goner.
- adriano
Re: An Old CD Issue
It's a no go.kassonica wrote:A real LONG LONG SHOT
Should I put it in a pan with some olive oil and garlic and remove from the pan as soon as it starts to deform?
I heard that garlic is good for anything.
Re: An Old CD Issue
I pretty sure that the easiest way to damage a CD is from the label side, because of the situation you describe. I put those paper labels on things I want to keep for that reason. The bottom side is a layer of thick plastic than can be polished if it gets scratched. The top is very thin, if you damage the metal it’s gone.
bb
bb
- kassonica
Re: An Old CD Issue
adriano wrote:It's a no go.kassonica wrote:A real LONG LONG SHOT
I tried to help
- adriano
Re: An Old CD Issue
Hi kassonica.
I really appreciate your help and everyone's else. I was totally kidding. Please, don't take it personal it was just a joke.
Thanks again
Adriano
Thanks again
Adriano
Re: An Old CD Issue
Since we've determined that the CD is a lost cause, but the info on it is irreplaceable and valuable, try this: Peel off all the top laminate and spray the top with an even coat of aluminum paint. LET IT DRY THOROUGHLY!!!
Then, place it in a CD player that you DON"T CARE ABOUT DAMAGING!!!
In theory, it is possible, maybe, that there is a snowball's chance in hell, that this sort of thing could work, kind of, or at least could produce the result of an Urban Legend about repairing damaged CDs that could be repeated endlessly throughout the Internet without a shred of evidence proving its efficacy.
Also, the garlic couldn't hurt, either.
- adriano
Re: An Old CD Issue
Thanks cuttime.
Good idea and it's worth a shot. I'll post back with the results.
Adriano
Adriano
