828 mk3 problems/help?
Posted: Wed May 12, 2010 5:00 pm
by blondie-jayne
Hi,
This is my first post here. Got my motu 828 mk3 last week and have it up and running with cubase 5 on my dell studio 1730 laptop. When I try and move the buffer size from 1024(or whatever) down to even 520(or whatever it is) it glitches and squeals. I need it at 256 to monitor vsti's without noticable latency but cubase crashes if I try to put it below. I have 4gb of ram also on the laptop and though it could handle it!?
I'm also having a problem with the firewire device losing connection during a session and I get a "no motu device detected" and hear the hardware being disconnected sound. Would really love to hear some suggestions from some experienced guys here! Thanks B-)
Re: 828 mk3 problems/help?
Posted: Wed May 12, 2010 5:02 pm
by blondie-jayne
... just to add i've got the latest drivers from the motu site installed and im on 32 bit vista!!
Posted: Wed May 12, 2010 5:44 pm
by WayneM
How is it connected up to the laptop? Is it plugged into the built in firewire port or have you fitted a Express card firewire port?
Posted: Thu May 13, 2010 1:55 am
by blondie-jayne
Hooked through my firewire port on the laptop.. 1394 connection!
Posted: Thu May 13, 2010 11:01 pm
by WayneM
It may have a something to do with the in built firewire chipset on you computer. I know people with similar problems that have been fix by installing an express card with a TI (texas instrument) chipset.
This is a good one http://www.sonnettech.com/product/fwusb ... ard34.html" onclick="window.open(this.href);return false; or this one http://www.sonnettech.com/product/fw800 ... ard34.html" onclick="window.open(this.href);return false; but you will need a firewire 400 to 800 adapter.
Posted: Fri May 14, 2010 7:24 am
by blondie-jayne
Thanks for that, ive heard about these. will it make a big difference from the 1394 port on my laptop do you think? I also have the 800 to 800 cable! Thanks for the info!
Posted: Fri May 14, 2010 3:03 pm
by blondie-jayne
Just to confirm.. is the 6 pin firewire cable 800 speed?? I've got 6 pin to 4 pin going into my laptop. If I get a Ti chipset card will i be able to get speeds of 800??? thanks!
Posted: Mon May 17, 2010 8:10 am
by jpleong
blondie-jayne wrote:Just to confirm.. is the 6 pin firewire cable 800 speed?? I've got 6 pin to 4 pin going into my laptop. If I get a Ti chipset card will i be able to get speeds of 800??? thanks!
No, the 6-pin is not FW800.
The mk3 FW products are FW400 but are forwards-compatible with FW800. Check your Device Manager to see what chipset you computer has for the onboard FW port. A TI chipset is essential to smooth operation. Make sure all drivers are up-to-date on your machine. Various components can interfere with the proper operation of the FW port, so you may also need to disable hardware or software.
JP
