best harddrive for intense virtual instrument steaming???
bell222
Post by bell222 »
Anyone know what the best external harddrive for streaming intense virtual instruments like Ivory, Kontakt, Reaktor? I'm running DP 7.11u. I'm using a Macbook Pro I7 and will be doing allot of live stuff so I can't have a slow drive. It's going to be running FW800. I was thinking of the 1TB Gdrive. Here's the link. I've heard these are extremely dependable. http://www.g-technology.com/products/g-drive.cfm" onclick="window.open(this.href);return false;
Digital Performer 7.22 | Macbook Pro i5 | Focusrite Saffire Pro 14
Re: best harddrive for intense virtual instrument steaming???
I went with this enclosure:
http://www.newegg.com/Product/Product.a ... 6817182123" onclick="window.open(this.href);return false;
Loaded up with this drive:
http://www.newegg.com/Product/Product.a ... -_-Product" onclick="window.open(this.href);return false;
Grand total: About $150. Couldn't be happier. It's quiet and been working like a champ!
If you have time, you can check out this thread:
http://www.motunation.com/forum/viewtop ... 26&t=40701" onclick="window.open(this.href);return false;
I pretty much agonized over this like you're doing now. Saw your other post though about wanting to go USB with MIDI/Audio interface and not sure about that one, though. Might be some other suggestions forthcoming.
bell222
Post by bell222 »
Is it FW800? I couldnt' tell from the link.
bell222
Post by bell222 »
would you say it's as dependable as the Gdrive?
bell222
Post by bell222 »
Also found something around your same price range. http://www.ramjet.com/itemdescr.asp?Item=F8W15T" onclick="window.open(this.href);return false; What do you think?
bell222 wrote:Is it FW800? I couldnt' tell from the link.
Yes. It's FW400, FW800, and eSATA as well.
bell222 wrote:would you say it's as dependable as the Gdrive?
I don't know. I never owned a G-drive. It really boils down to the enclosure components since the drives are not made by G-drives. So far I'm very happy with mine.
newrigel
Post by newrigel »
You have one bottleneck... IEEE 1394b. You could get the best drive made and it still only perform @ FW speeds so the mechanism isn't going to be a real issue here. On the iMac your only option is FW so that's all you'll get. When Apple puts Light peak into all their boxes, you won't have these issues anymore... well, for a few years anyway until they scale the protocol to 100 Gb/s.
bell222
Post by bell222 »
newrigel wrote:You have one bottleneck... IEEE 1394b. You could get the best drive made and it still only perform @ FW speeds so the mechanism isn't going to be a real issue here. On the iMac your only option is FW so that's all you'll get. When Apple puts Light peak into all their boxes, you won't have these issues anymore... well, for a few years anyway until they scale the protocol to 100 Gb/s.
No, it's a Macbook Pro with a ESata card option which is what I would stream my drive to.
screws
Post by screws »
James Steele wrote:I went with this enclosure:
Hey James, would this drive work internally in my Mac Pro 1,1?
Steve Cruz
Cruzified Music Productions
Florida
screws
Post by screws »
Take a look here:
http://eshop.macsales.com/item/Western% ... /WD15EARS/" onclick="window.open(this.href);return false;
OWC has a 1.5 TB Western Digital drive for $110.00. Any comments on WD drives?
Steve Cruz
Florida
Sure does. I bought a used Mac Pro 1,1 and simply took the drive out and installed in the Mac Pro without missing a beat!
newrigel
Post by newrigel »
I could have sworn you said this: I'm using a Macbook Pro I7 and will be doing allot of live stuff so I can't have a slow drive. It's going to be running FW800.
This is why I stated that... sorry. In that case, anything would do. You could spend the $$ on a Velociraptor and be done with it. If performance is paramount, then a 600 GB (if high capacity is what your after) velociraptor or any type of 10k rpm drive will win out. I should have figured it out by the 17 inch moniker but you did state FW 800.
mikebeckmotu
Post by mikebeckmotu »
screws wrote:Take a look here:
I've had, generally, slow performance from WD drives. I'll use them for backups, clones, but not streaming audio or recording. Granted, it's possible there may have been quirks about my systems that didn't get along with WD, but it seems unlikely.
For each time I've replaced a WD drive with another brand, performance has gone up.
I should be clear that I'm talking about 7200rpm off-the-shelf external drives, and not custom-enclosure builds or bare-kit internals.
8-core i9 MacBookPro 16-inch, 16gb ram, Catalina, Focusrite Scarlett 18i8, DP not installed yet
