When I use "parallel compression" on a drum mix, the way I normally do it is send all my drum tracks to 2 separate "Aux" tracks. One with a slight amount of reverb and minimal compression and the 2nd Aux track I totally squash with tons of compression. I nomrally don't print either AUX track and simply have them both active (Aux to much lower than Aux 1) when summing.
If I want to use an external compressor I just send the drum mix out through 'analog 1-2' and then bring it back in on a stereo track and print it. I don't however know how to print an Aux track. I thought I did but I don't. So my basic question is how to i print or record an aux track?
Thanks in advance!
printing an Aux track??
Mac Pro 3.2, 8 Core. Mac Book Pro 2.4 GHz Intel Core 2 Duo. Power Mac G5 Dual 2.0. (2) MOTU 2408 MK3's (BLA Mods) & 8 Pre. Motu Micro lite for MIDI (interface for Mac Pro) MOTU Ultralite MK3, Dp 7.2, Reason 4, Ethno 2, MX4, Symphonic Instrument, Mach 5 V2, Electric Keys, Ivory II Grand, Arturia CS-80V, Arturia Prophet V.2, PSP Vintage Warmer, Softube Trident A-Range EQ, IK Classik Reverb, Focusrite Liquid Mix, Peak LE
Affordable "E" Drum session work: gongbass@msn.com
Re: printing an Aux track??
Just assign that auxillary to a stereo or mono bus and set an audio tracks inputs to the same and record.
