Master Room Spring Reverb
TheHopiWay
Post by TheHopiWay »
I was listening to some mixes I did back in 1980 and loving the vocal verb, a Master Room spring reverb.
I don't recall the model number, 3 something comes to mind.
Anyway, is there a plugin based on the Master Room stuff?
Impulses for convolution verbs maybe?
I may need to just research the models somehow and scour ebay for a real one..........
TheHopiWay
Re: Master Room Spring Reverb
I found these impulses from a model II.
http://www.xs4all.nl/~fokkie/IR.htm#Masterroom" onclick="window.open(this.href);return false;
Now all I'm missing is the 2" MCI, the Neve console and the 1/2" ampex I did the mixes with.......
burn em
Post by burn em »
May I ask the context you used this verb in? I have a mix to finish later on tonight that I might try this on a guitar that need a bit of *something*.
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
newrigel
Post by newrigel »
Hey Hopi... There's engineers doing that type of thing from what Ive read. Running spikes from console channels and running concurrent instances to make virtual analog consoles.
bongo_x
Post by bongo_x »
TheHopiWay wrote:I found these impulses from a model II.
What format are those in? Something to do with Altiverb? I'm trying to figure them out.
bb
TheHopiWay
burn em,
the context was this:
At the time I did the mixes, studios generally had very limited choices in reverbs. Either a plate or a spring or a chamber.
This particular studio had the master room reverb as it's only choice.
The only other ambiance on the tracks were from micing techniques or tape delay.
bongo x
As to the format of the impulses I believe them to be altiverb.
As it turns out I've been unable to use them.
The search continues.
