Alphatrack (moved to troubleshooting forum)
labman
Post by labman »
Is alphatrack working fine inside DP7.02 et al?
slicerecords
Re: Alphatrack
Post by slicerecords »
I haven't had any issues with that combo.
PowerMac G5 Dual 2.5Ghz, 6GB RAM, 10.5.8, DP 7.11, 828mk3, Waves Platinum V7, Komplete 5, VSL Special Edition Plus Byndle, URS Everything Bundle...
Re: Alphatrack
Yes... it is SAFE... go ahead... it'll be okay... trust me...
Working for me in 7.02 and now in 7.1.
labman
Re: Alphatrack
Post by labman »
Thanks folks. Very appreciated. We will move it from our DP5 rig to the DP7 then.
labman
Re: Alphatrack
Post by labman »
We are getting odd behaviour on this macpro in DP 7.02. Installed Alphatrack driver 1.02 and the DP bundle. Do we even need the driver or just the bundle? What versions are you foks using?
labman
Re: Alphatrack
Post by labman »
Here are the details of our whacky behaviour.
We had installed driver 1.20 and the DP control surface bundle 1.01. Got lots of odd behavior in DP. See below. Uninstalled driver 1.2 and installed 1.3.0 driver. Same behavior.
When we select a trk in DP, the AlphaT scribble strip text never shows up. Also, wHen you pull the ALphatrack fader up it immediatley jumps back to the floor (0) even if the dp track has no automation data on it, and the auto play enable is off. The only thing that DOES work is the transport controls. Hmmm.
Oh yeah, AT software is of course set to native.
We just checked and reconfirmed that this unit is working flawlessly on the aforementioned G5 running DP 5.11, OSX 10.4.7
Any ideas?
