Effects on Master Track?
gongbass
Post by gongbass »
If I apply effects to a "master track", are they in fact being applied to the whole mix? I'm just not sure I'm clear on that. Does the Master Track act as a "summing device" in which anything applied to that track would be similar to a stereo effect applied to a final stereo track?
Mac Pro 3.2, 8 Core. Mac Book Pro 2.4 GHz Intel Core 2 Duo. Power Mac G5 Dual 2.0. (2) MOTU 2408 MK3's (BLA Mods) & 8 Pre. Motu Micro lite for MIDI (interface for Mac Pro) MOTU Ultralite MK3, Dp 7.2, Reason 4, Ethno 2, MX4, Symphonic Instrument, Mach 5 V2, Electric Keys, Ivory II Grand, Arturia CS-80V, Arturia Prophet V.2, PSP Vintage Warmer, Softube Trident A-Range EQ, IK Classik Reverb, Focusrite Liquid Mix, Peak LE
Affordable "E" Drum session work: gongbass@msn.com
rainmaker
Re: Effects on Master Track?
Post by rainmaker »
Indeed you're correct.
FMiguelez
Post by FMiguelez »
You got it totally right.
And precisely because of the facts you just stated, it's VERY easy to ruin an otherwise perfect mix by unnecessarily messing with Fx in the master bus :)
That's where you'd put your mastering plug-ins if you want to do it yourself.
Also, that's where you would leave things alone (empty) if you want to have it professionally mastered. Generally.
