No 3rd Party plugs work after upgrade to DP7 [SOLVED!]
Tripp
Post by Tripp »
I've been using DP 5.13 on my MacBook Pro with OSX 10.4.11. I just installed DP 7 and then the update to 7.02. None of the GUI's are working for any of the 3rd party plugins I have like Free G, Guitar Rig 3, or even the Apple AU plugs. I can insert a plugin and it does work. I can also call up an existing project that has modified values for these plugins and they work. I just can't update any value via the GUI. In fact, the GUI isn't rendering all the way in some cases.
All of the MAS plugins work fine.
Any ideas?
Tripp
Re: No 3rd Party plugs work after upgrade to DP7 [SOLVED!]
Post by Tripp »
I found out what the issue was. In my MAS plugin directory (System->Library->Audio->Plug-Ins->MAS) I had created folders to organize the MAS plugins so that they would be easier to find grouped that way in DP5. When I installed DP7, the installer placed all of the MAS plugins in that folder instead of the grouped folders. This caused plugins to be duplicated in the MAS directory.
Once I deleted the grouped ones out, all was well...not to mention DP7 loads much faster now!
