Firewire 800 to 400 Converter
Has anyone had any experience with these?
I'm thinking of picking up a new Mac, but, of course, they all come stock with FW 800 and everything I have is 400.
MacBook Pro 2.5 GHz Quad-Core Intel i7/16GB, OSX 10.14.6, DP 10.1, MOTU 896mk3
- Pappy725
Re: Firewire 800 to 400 Converter
Got mine when I got my new MBP. Works great, but my MBP only sees my 828mkII if my 8pre is FW'd in first. Not a deal breaker, but a minor annoyance.
Pappy
Pappy
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
Thanks, Pappy.
We'll see what happens when a Firebox tries to talk to a new Mac-mini.
Is there really any conversion going on? Or is FW800 just backwards compatible with FW400, and it's just a matter of making the right connections?
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
No conversion. Just an adaptor to get the pins lined up. Try MONOPRICE.com for your cable/connectors. Great prices and low cost shipping to boot.nick danger wrote:Is there really any conversion going on? Or is FW800 just backwards compatible with FW400, and it's just a matter of making the right connections?
- mhschmieder
That's right; these are simply cables that change the pin arrangement to be compatible. There is no conversion going on.
The only thing you need to be concerned about is daisy-chaining in the correct order, if you have a combination of FW400 and FW800 devices, so that the FW400 device doesn't pull the FW800 device down to FW400 rates.
Mac Studio 2025 14-Core Apple M4 Max (36 GB RAM), OSX 15.4.1, MOTU DP 11.34, SpectraLayers 11
- ericsvizeny
Go to your local mac store, they have them there for about $15 bucks and work great!
- Pappy725
OWC has an adapter for $9.95. I'm thinking about getting one so I can use the 15' cable that came with my 828mkII all those years ago. The one I got from the Apple store is only 6'. Didn't realize how short that really is.
Pappy
Pappy
I've got a 400-800 adapter, which allows me to continue to use the many FW 400 cables I have lying around, but my complaint is that it inadvertently disconnects too easily. Since every firewire device is disconnected from my iMac when that happens, that can be a little annoying.
