Using Cuemix's compressors while mixing in Cubase?
mandobilly64
Post by mandobilly64 »
Hey guys,
I have been reading on how I can use the second set of ADAT ins and out to access Cuemix's channel strips while doing a mix, and not just while recording. My question is, how do I need to set up Cubase so that I can adjust the channel settings in Cuemix while Cubase is running? I am using an 828mk3 with Cubase SX3. In my past experience, every time I have tried to change anything in Cuemix while Cubase is running, Cubase stops when I do. So I am just wondering if it's possible to make adjustments while Cubase is running.
Thanks in advance for any help,
Billy
dougle03
Re: Using Cuemix's compressors while mixing in Cubase?
Post by dougle03 »
Hi,
Not sure where exactly, as I don't have Cuebase up on this machine, but in one of the cuebase devise settings there is an option called something like "Release ASIO drivers in background"
This option is most likley on at the moment, On by default I think!
What this does is disconnect Cuebase from the ASIO drivers (I.e no sound) when you make another other program the active in windows, such as bringing up the Cuemix FX window.
Switching this off allows Cuebase to continue working even when you minimise it's window (Or lose focus!)
Un-check the option box and you will find bringing up the cuemix window will not stop Cuebase.
Cheers
Pete Kay.
Turtle Mastering Studio
Studio rig: Cuebase
Custom PC:AMD Phenom II 955,WinXP 32,4gb ram,Raid0 disks,dual 22" monitors.
Yamaha 01x control and interface,rack kit and mics.
Road Kit:Cuebase & Cuemix FX
Motu 838 mk3 + 2x Focurite LE's on litepipe
Custom Rack PC:AMD Athlon II Quad,4gb ram,Raid0 SATAII,2x 21" monitors,Dell Tablet PC system setup and Cuemix control,Studiospares 32way snake,Shure & AKG Mics,custom 24 way splitter,4x DP IEM sets
mcoyles
Post by mcoyles »
Devices > Device Setup > VST Audio System
Tick box is under the ASIO Device Selector dropdown.
L8rs...
Marci
mandobilly64
dougle03 wrote:Hi,
Cheers
Right on, I'll give it a try and see what happens.
Thanks,
Billy
mandobilly64
Ok, so I tried the release ASIO drivers but to no avail, just doesn't work, as soon as I bring the Cuemix screen up Cubase freezes.
Oh well.
Peace,
Billy
