Ethno in Snow Leopard
Posted: Mon Sep 07, 2009 12:10 pm
by tonester
Hi:
Upgraded to Snow Leopard. Downloaded the latest PACE extension drivers, but upon launching DP6.02, I get a "fatal error" when Ethno is scanned. Same thing if I try and open the standalone. No error codes with MachFive 2 or MSI.
Any hints?
Thanks.....
Re: Ethno in Snow Leopard
Posted: Mon Sep 07, 2009 12:12 pm
by Dwetmaster
MOTU has announced that ethno isn't compatible with Snow yet. If you have MachFive, use Ethno's sound in M5.
Posted: Tue Sep 08, 2009 6:01 am
by tonester
Dwetmaster wrote:MOTU has announced that ethno isn't compatible with Snow yet. If you have MachFive, use Ethno's sound in M5.
So should I uninstall the ethno program and leave the sound files? as I said, I can't open DP6.02 with ethno still on the HD
Posted: Tue Sep 08, 2009 6:57 am
by magicd
Yes, you should remove the Ethno Plug-ins from both the MAS and Components folder:
Hard drive>Library>Audio Plug-Ins.
You can use the Ethno library within MachFive 2 (if you own it) or UVI Workstation (which is a free download if you don't already have it).
Dave
Posted: Tue Sep 08, 2009 8:41 am
by tonester
thanks! yes, i have machfive2, so i'll use that until they fix ethno......
Posted: Tue Sep 08, 2009 7:47 pm
by waxman
Will Ethno work in Konkakt 3.5
Posted: Tue Sep 08, 2009 9:16 pm
by Shooshie
waxman wrote:Will Ethno work in Konkakt 3.5
I don't think so. But you can use its sounds in either Mach5.2 or UVI Workstation.
Posted: Wed Sep 09, 2009 2:06 am
by corbo-billy
No, the ETHNO'S files don't work with KONTAKT 3.5 ; it could be possible knowing that KONTAKT 3 is compatible MachFive !
Posted: Thu Sep 10, 2009 2:59 am
by waxman
Anyone get Ethno to work in UVI?
Its working now for me
Posted: Sat Sep 12, 2009 3:24 pm
by waxman
After using UVI workstation for a few hours with SL and DP 6.02 I am finding UVI is not stable. I had a couple of crashes. I might be using it wrong but basically try to track as soon as possible and get UVI out of the project...
Posted: Sat Sep 12, 2009 11:56 pm
by corbo-billy
Here, UVI work only in Plug-in mode under Snow Leopard and not in Standalone .
Posted: Mon Dec 07, 2009 4:47 am
by simdrum
How do you play Ethno sounds through the Mach V?
Posted: Fri Mar 05, 2010 8:36 pm
by 31flies
To remove Ethno the previous post said:
"Yes, you should remove the Ethno Plug-ins from both the MAS and Components folder:
Hard drive>Library>Audio Plug-Ins."
I don't have Audio Plug-ins in Hard drive>Library...how could that be? Where do I find MAS and Components then?
Thanks.
Posted: Fri Mar 05, 2010 9:28 pm
by 31flies
Nevermind (...I have much of the old MacPro, plus two external drives dumped onto new iMac...got lost in a messed up Library...sorry for the bogus post...)
Posted: Sat Oct 06, 2012 12:10 pm
by tikibars
Hi all,
I didn't see this spelled out elsewhere, so I'll post it here, and also on the two other threads that deal with this same issue.
MOTU has confirmed for me that Ethno 1 no longer works on Mac OS10.6 and above.
Anyone getting that Fatal Error issue on OSX10.6 or above may as well trash their copy of Ethno, it is now obsolete.
