I have been using Presonus audiointerface card which do not provide hardware mixing or DSP effects like compressor,limiter etc.
This is a feature I wery much would like to have in addition to the possibility of using it as a DAW interface.
That's why I have been looking at the MOTU cards. I hope I can get some help here as I am a bit confused at the moment
I will be using Win Xp 32 and Sonar8 as DAW. Don't think thats a problem.
I come over a used MOTU 896HD. It has got 8 mic preamp inputs but I would like more inputs than my current Presonus card provide.
Then my question is if 896Hd can be used as expansion for another MOTU card and have both units controlled via the CueMix software ?
It is possible to feed another MOTU card with ADAT but as I understand it is limited to 4 channels
at 96kHz but perhaps a fifth channel can be added via AES/EBU ? I would like to find a new MOTU
card that has got on board DSP effects. Don't think 896HD got SDP effects ? Only DSP mixer ?
I would also like to set the analog input levels from the computer. Is this possible on 896HD and other MOTU cards ?
Seems like its pssible to buy used MOTU 828mk2 or mk3 at reduced price (I even found some other cards). With mk3 I
should be able to add DSP effects for all channels including those from 896HD expansion ?
Can I daisy chain via firewire and still be able to use DSP effects pr. channel in the mixing unit or must all channels be transferred via ADAT ?
Anyway I guess 400Mbps firewire is capable of less than 10 channels at 24bit/96kHz ? Then MOTU PCI card
will be needed for more than 8 channels recording simultanously at 24bit/96kHz ?
What will the limitation be in number of channels at 96kHz when using 896HD as expansion for MOTU 828mk3 ?
Is there any other combination that will be more sensible than 896HD->MOTU 828mk3 when I want to record more than 8 channels at 24/96
and be using DSP mixer and the DSP effects ?
Is there any big drawbacks with an old 896HD and what will the value be compared to new price ? 50% , 30% , 10% ?
Unfortunatly I could not find any usermanual for the 896HD or for the CueMix software. Seems like you only can buy the manuals.
Is MOTU mk4 cards just around the corner ? ( that will probably make more used mk3's available...)
