OS 10.5.8 released
OS 10.5.8 released
http://www.versiontracker.com/dyn/moreinfo/macosx/29147 (about 250MB)
Software update is about 165MB.
Better yet and safest, the combo updater:
http://support.apple.com/downloads/Mac_ ... mbo_Update
It's about 760+ MB (I got it right that time, Mr, Frodo!)
kassonica
Re: OS 10.5.8 released
Post by kassonica »
OK who's first (ps not me)
kassonica wrote:OK who's first (ps not me)
What the heck... I'm in! :) Especially since Core Audio stuff was supposed to be in this one.
bdr
Post by bdr »
Where did you hear that James? I just had a look at the fixes and audio wasn't mentioned.
Additional Information
What's included in this update:
Upgrades Safari to version 4.0.2.
Improves the accuracy of full history search in Safari 4.
Resolves an issue in which certain resolutions might not appear in the Display pane in System Preferences.
Dragging an Aperture image into Automator now invokes an Aperture action instead of incorrectly invoking an iPhoto action.
Resolves an issue that could prevent importing of large photo and movie files from digital cameras.
Improves overall Bluetooth reliability with external devices, USB webcams and printers.
Addresses an issue that could cause extended startup times.
Improves iCal reliability with MobileMe Sync and CalDav.
Addresses data reliability issues with iDisk and MobileMe.
Improves overall reliability with AFP.
Improves overall reliability with Managed Client.
Improves compatibility and reliability for joining AirPort networks.
Improves Sync Service reliability.
Includes additional RAW image support for several third-party cameras.
Improves compatibility with some external USB hard drives.
Includes latest security fixes.
DId it. So far so good. I'll go put DP thru some paces in a little while... Finale first.
Took about 35 minutes, BTW. Used the combo updater.
kassonica
Post by kassonica »
Let us know how you go ok :)
bdr wrote: Where did you hear that James?
James knows all; sees all. There's no escape.
You know, I saw just now that audio wasn't mentioned. One of the Mac rumor sites had mentioned that Core Audio or Core MIDI was getting some tweaks in one of the final candidate releases. I'm sure I saw that somewhere, but you're right... can't find anything about it on that same web page you went to. Hmmm... well I'm installing it anyway. Wish me luck! LOL
Quick and dirty.
Finale seems fine.
DP 5.13 took a very long time to load and the Plugsound Pro VI in particular just stood there for the longest time, but it did load and DP 5 seems fine.
DP 6.02 loaded fairly quickly (even Plugsound Pro) but something has changed. Bounce to disk works now! I could not BTD and stopped using DP 6.02 becuase of that as the first 6 seconds or so dropped out. I did a quick check and sure enough, the entire file bounced just fine. So perhaps James "the Yogi" Steele read correctly that Core Audio was addressed. How nice would that be?
Safari seems fine. I'm hungry. OMG! The OS update made me hungry. DAMN YOU APPLE!!! :) I'M HAVIN' MEAT TONIGHT!!!
kassonica
Post by kassonica »
Well good hear MLC.
I'm still waiting though cause I'm on intel if they have fixed something on PPC it may break on intel :mrgreen:
Kubi
Post by Kubi »
2x2.8GHz Quadcore Intel Xeon: After updating to 10.5.8 (procedure: repair perm, restart into safe mode, updating from Combo Updater) did a very quick test, opening a few files and loading a few plugs - DP5.13 seems completely unfazed. As if I hadn't changed a thing. Thumbs up so far. :D
wayneconnor
Post by wayneconnor »
Cuemix working fine for me under 10.5.8
nick danger
Post by nick danger »
The Apple remote on my G5 iMac isn't functioning.
Edit-- after about a 3 minute delay, the volume control I entered finally took effect.
Attempts to use it currently are not working-- I suspect that will take effect in a few minutes, as well.
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
nick danger wrote:The Apple remote on my G5 iMac isn't functioning.
Stuff might still be updating, but if that continues, reapply the COMBO UPDATER.
nick danger
I tried a restart, but it wouldn't do so. Under Activity Monitor, it was indicated that loginwindow was not responding, so I force quit, and was able to restart. Following restart, things seem to be functioning properly.
