Each time I minimise Cue Mix my PC re-boots itself.
Is this a problem anyone else has had and can advise on, or if anyone has any ideas I could check.
I am using Ultralite Mk3, and Windows XP.
Minimising Cue Mix cause PC to re-boot
Gigabyte H55M-UD2H, Intel Core i7 860 @ 2800 MHz, 4096 MB (2 x 2048 DDR3-SDRAM )
Windows 7 Pro 64-bit, Soundcard : MOTU Ultralite Mk-3, Sonar : Studio 7.0
- Primary DAW OS: Windows
Re: Minimising Cue Mix cause PC to re-boot
You need to setup windows so it wont automatically restart upon a problem.
Go to System Properties Advanced tab( you get there by right clicking My Computer, selectiong properties, and then Advanced System settings), and click Settings under Startup and Recovery, under the System Failure section, uncheck mark "Automatically restart."
Now when this happens again you will get a BSOD (Blue screen of death). Look at the top and bottom to see what error message you get. Write it down, and let us know. This problem is usually a driver problem, but it could be a memory problem (RAM), or something else.
Take note of what message is in the BSOD, and you can troubleshoot from there.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
SONAR X1a Producer
Hello HotShot, and thanks for your help.
Not wanting to get the BSOD death uless I really had to (!) I went to Event Viewer and found the log of the error - will this give me the same information as the BSOD?
It shows :
Source . System Error
Event ID : 1003
Error code 100000d1, parameter1 00f77000, parameter2 00000002, parameter3 00000001, parameter4 a9707de2.
If this helps, my PC specs .
Intel Core 2 Duo E8400 3.0 GHz
3 GB RAM
ASUS P5Q-Pro
Windows XP Serivce pack 3
MOTU driver 3.6.8.1400
Thanks for any feedback on this.
It shows :
Event ID : 1003
3 GB RAM
ASUS P5Q-Pro
I'm not an IT specialist, but Event ID 1003 seems to be related to networking.
You already receive a BSOD, you just don't see it because you have "automatically restart" selected to happen when you get a system failure. Uncheck mark that and you might see the specific file listed in the BSOD that's causing the problem. Then, you can, determine what actions to take to resolve the issue. For example, do you need to update your network card drivers, motherfboard drivers, etc.
If you're unwilling to take further actions (such as letting the BSOD show so you can see if a certain file is listed in the BSOD error message) to pinpoint the source of your problem. I can offer no more help because I'm not really familiar with analyzing windows dump files and such.
Maybe someone else will come in and can be a better help to you.
Goodluck.
Goodluck.
SONAR X1a Producer
SONAR X1a Producer
Hey
what type of FireWire card do you have? I had exact same problem with
my 828mk3. I fixed it by buying another pci FireWire card. This reslved the irq issues I had with old built in f/w port. Cost me 60$ but well worth it Now my unit run rock solid. I got a pyro card (as recomended by motu). Good luck
