I bought MOTU 896 from secondhand, look very proved and funcionally ok ! When i turn on, all LEDs flash. And LED panel indicator reacts to input signals.
I have windows XP 32bit, now i additional install SP3, AMD dual core 2600Mhz, 2GB Ram, motherboard gigabyte(
Code: Select all
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=2579
I install MOTU_Audio3.6.7.0 driver, try too 32fw-3.6.8.1410, pc every time found motu 896, and installing seems to be ok ! I can with Motu Audio Setup change samle rate and others in Motu Audio Setup. Motu reacts on Motu Audio Setup, but Motu CueMix doesn't work and write: "No Motu Audio Devices that support CueMixDSP found".
for example... in windows audio setting are motu analog input(1-8) and too output, MIDI. Cool edit find cues(1-8) and i can record every cue separately.
But without cueMix console is it bad.
Can you help me ? Thanx !!!
