MSI question
MSI question
Hi:
I've been experiment with MSI in DP6, trying to set up templates and all that. Correct me if I'm wrong here, but technically I could have a 64 piece orchestra, right? Since there are 4 banks of 16 channels, I could put a different preset on each channel, and set up MIDI tracks for each of them, all from one instance of MSI?
I guess the only thing limiting me would be RAM and polyphony, which may not even be an issue, since instruments like percussion don't really require many voices.
am I right in what I'm assuming here? If so, this thing could be a monster.......
Thanks,
anthony
Thanks,
anthony
Re: MSI question
Yes, you can definitely do that. If you need more than 64 sounds, just add another instance of MSI.
Re: MSI question
You have to consider factors like hard drive performance, RAM usage, other resource-intensive parts of the project like effects plug-ins and other VIs, etc.tonester wrote:I guess the only thing limiting me would be RAM and polyphony, which may not even be an issue, since instruments like percussion don't really require many voices.
Re: MSI question
That's what I thought I was reading according to the manual, but I wanted to make sure I wasn't reading wrong. So this thing can be pretty powerful. Ethno can do the same thing.carrythebanner wrote:Yes, you can definitely do that. If you need more than 64 sounds, just add another instance of MSI.
So I think it's a pretty powerful VI. I see a lot of negative posts about it though. I don't get it. I think it sounds pretty good to my ears. Maybe not VSL quality, but the price is certainly right. And apparently, it's pretty flexible as well.
Thanks,
Anthony
Re: MSI question
Anthony, you are absolutely right. I spent some time with MOTU SI this week in DP and I got a whole new level of appreciation for this. The strings, in fact, sound much better than a lot of other libraries in its price point. Miroslav is nice but only in its non-looped samples and its short articulations are under represented and weak. MOTU SI short string articulations are actually very good. The upper range of the violins is actually quite good to my ears- as good in their attack transient as the EW's and VSL's of the world. Perhaps not on the level of LA Scoring Strings but that library is much newer and more expensive.tonester wrote:That's what I thought I was reading according to the manual, but I wanted to make sure I wasn't reading wrong. So this thing can be pretty powerful. Ethno can do the same thing.carrythebanner wrote:Yes, you can definitely do that. If you need more than 64 sounds, just add another instance of MSI.
Thanks,
Anthony
The brass are decent but I dearly wish MOTU would do a nice update to some of the wind samples which are by far the weakest of the lot. But I love the player bundled with SI- it makes customizing keyswitches, changing the ADSR or filters or even x-switching a synch.
Mac Pro 2.66 ghz w. 15 gb RAM, DP 7.24, Kurzweil PC3x, MOTU 2408Mk3, Symphobia 1&2, LASS, VSL VI/VE Pro,MOTU Mach5.3, SI & Ethno 1, Omnisphere, Trilian, CineBrass, Albion, tons more...
Re: MSI question
Agreed . . . I've been increasing my usage of SI in projects and I'm liking it more and more. I especially have found a good use for the piano sounds. Maybe not as high quality as Ivory, but it definitely gets the job done at a great price with an easy, powerful interface.
That being said, the brass is ok at best but with the right levels, reverbs, etc., . . . well, let's say I've heard a whole lot worse.
DP 11
iMac M1 (24-inch, 2021) 16GB RAM
OS X 11.6.2
Re: MSI question
There are nevertheless some problems; the strings are "slow" to my taste, this makes very short notes sound weak.
And some notes can't be hold long enough (voices, recorders...).
I know people must breathe, but real players or singers can sound longer than some MSI instruments. In final cadences I often have to rearticulate some notes which would normally be tied, because they stop too early
