DP6 Spectrasonics Workaround
thinkof1
Post by thinkof1 »
I've found a workaround to get Trilogy and Atmosphere running fine on DP6. The 6.0.2 update didn't change anything, by the way. You need the VST installer for Trilogy and Atmosphere, and Fxpansion's VST to AU adapter ($49).
All you have to do is use the VST to AU adapter to create AU's using the VST plugin files. Throw out or disable the regular AU's since they no longer work in DP6. Also, move your .dat files to the VST plugins folder or create new aliases there. Somehow the converted VST's work fine in DP6. Enjoy.
Digital Performer 5.12
Macbook Pro 2.4 ghz 4GB RAM 160GB HD
Power Mac G5 Dual 2.0 ghz 2GB RAM 320GB HD
Motu 828 mkII
iPerformer
Re: DP6 Spectrasonics Workaround
Post by iPerformer »
thinkof1 wrote:I've found a workaround to get Trilogy and Atmosphere running fine on DP6. The 6.0.2 update didn't change anything, by the way. You need the VST installer for Trilogy and Atmosphere, and Fxpansion's VST to AU adapter ($49).
Hi thinkof1. Is this workaround for intel Macs running Leopard?...
Thanks.
hammerman
Post by hammerman »
Hey thinkof1, thanks for the info. I went ahead and purchased the Audio Ease VST Wrapper and it works great with Trilogy. Stylus and Omnisphere are obviously working great as is. Trilogy was holding me back. Looking forward to Trillian in June!
M2 Mac Studio Ultra - 64 GB RAM - Sequoia - DP 11
dweiss
Post by dweiss »
hammerman wrote:Hey thinkof1, thanks for the info. I went ahead and purchased the Audio Ease VST Wrapper and it works great with Trilogy. Stylus and Omnisphere are obviously working great as is. Trilogy was holding me back. Looking forward to Trillian in June!
How did you get this to work? I just get a blank box when I instantiate Trilogy. Thanks.
daveyboy
Post by daveyboy »
I just used Trilogy last night with the intel wrapper thingy in DP 6.02 with no issues. But, all I did was load up a sound and then bussed it to a mono audio track and printed it so I'm sure it's stiff unstable. I haven't tried the Atmosphere wrapper since I got Omnisphere.
Dave
www.dbwproductions.com
