Can't get MOTU Audio Console for original 896 on Vista
johng63
Post by johng63 »
I have a MOTU 896 (original not mk3 or HD) and I am working with it on Vista, I was able to get the drivers to work (with the help of one of the other posts) but the Audio Console has an error when I try to bring it up from the VST Multilink setup in Cubase 4 LE. Has anyone else been able to get the Audio Console up?
The reason I need the audio console is that I hope to be able to split the output buses so I can control all output volumes separately.. ie input 3 to output 3 and input 4 to output 4.. right now they are all grouped 1-2 3-4 5-6 7-8. Hopefully the Audio Console can control this.
FYI: I got the driver from: http://www.dontcrack.com/freeware/downl ... SB-Driver/#.
badnewsz
Re: Can't get MOTU Audio Console for original 896 on Vista
Post by badnewsz »
Need Help too!
tried a million things trying to install my new ultrlite on Vista (home). But getting error 1721 each time! Does anyone have a fix or maybe i am in the wrong forum. I have tried re installing drivers etc......
I have even tried in safe mode to try to install but get the message motu drivers not installed or motu card not found...
can someone firect me to the right place to find help>
Many Many thanks
Ngoma
Mark S
Post by Mark S »
johng63 wrote:I have a MOTU 896 (original not mk3 or HD) and I am working with it on Vista, I was able to get the drivers to work (with the help of one of the other posts) but the Audio Console has an error when I try to bring it up from the VST Multilink setup in Cubase 4 LE. Has anyone else been able to get the Audio Console up?
The channel groupings has always been a Windows thing. Was that supposed to be different in Vista? You just pick 1-2L or 1-2R,...
1nput0utput
Post by 1nput0utput »
badnewsz wrote:Need Help too!
Many Many thanks
Ngoma
Right-click on the driver installer program and select "Run as administrator." I think that will prevent the error your seeing.
classicsound
Post by classicsound »
Wow, I have been trying all day to install the .1414 USB/Firewire drivers for Vista 64bit on my brand new Dell XPS. I found the previous 3 versions by rooting around and they all had error 1721 and would not complete the install. I just tried "run as adminstrator" and version 1394 installed. I don't know if any of it will work yet, but atleast I am onto the second alligator head on the pond! Thanks!!!
