Lately I've relegated my 896HD to the piano room and the laptop, while using my Onyx 1640 down in the main basement studio. But I'm running into a very annoying problem. Apparently with my setup, there is simply no way to disable input monitoring on a record-enabled track. Turning Audio Patch Thru to 'off' doesn't do it. And Direct Hardware Playthrough is grayed out.
My workaround is to create a bus, called "mute bus," in the Bundles window, and route tracks I'm recording to that (unassigned, of course, to any output). But this means that every time I want to hear playback of a track I'm working on, I have to change the output assignment. Not the end of the world, but awfully clunky.
Is there really no simpler, more straightforward way to tell DP, when using a non-MOTU interface, that I don't want to monitor input signal? I feel like I'm back in the dark ages. Or else I'm being really really stupid. I hope it's the latter.
No way to escape input monitor?
- Brian Middleton
Brian Middleton
Night Kitchen
Dorchester, Mass.
DP 8.07, OS 10.10.2, MacPro Quad 2.8 4GB RAM/15" Macbook Pro mid 2010 4GB RAM, Mackie Onyx 1640, UAD-2, PSP42/84/608/Echo, Altiverb 5, Valhalla Vintage Verb, Stilwell Rocket/Major Tom/Vibe EQ, EZDrummer
Night Kitchen
Dorchester, Mass.
Re: No way to escape input monitor?
Take the track off "input"? (The speaker monitor icon per track...) That must be included in your Track Columns Preferences as an visible option.
Perhaps I don't understand your problem, but......can't you just mute the track when you don't want to monitor it?
-gabe
-gabe
Computer: 2019 Mac Pro 28-core 2.5gHz, OS 10.15.2, 96GB ram, all SSD/NVME drives, MH Labs ULN-8, MOTU MidiTimepiece AV
DP Setup: DP10.11, all Spectrasonics VIs, all Waves plugins, Sonnox AU, Altiverb, NI Komplete 12/K5+6, Plogue Bidule 64 as VI host
- Brian Middleton
Never mind. Total, total idiocy. I didn't notice that I had the input track assigned to one of the subgroups on the board. It wasn't assigned to the main LR bus, so I thought any signal must be coming from the DAW return.
James, any chance we can delete this thread?
Brian Middleton
Night Kitchen
Dorchester, Mass.
Night Kitchen
Dorchester, Mass.
