Altiverb 6
kristupes
Altiverb 6
Post by kristupes »
Does anyone know if Altiverb 6 works with DP 6.01 on an Intel Mac running Leopard 10.5.4?
kristupes
corbo-billy
Re: Altiverb 6
Post by corbo-billy »
Yes, no problem with this product from AudioEase under 10.5.5. _
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
rodger1811
Re: Altiverb 6
Post by rodger1811 »
No problems here!
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
Frodo
Re: Altiverb 6
Post by Frodo »
No problems here, either... Tiger or Leopard.
burn em
Re: Altiverb 6
Post by burn em »
Without getting too far off topic, AV6 is stereo only with no surround support?
If that is the case does DP6.01 support AV5 which I think still had surround support in the non Protools HD/TDM version?
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
Frodo
Re: Altiverb 6
Post by Frodo »
burn em wrote:Without getting too far off topic, AV6 is stereo only with no surround support?
Only partially correct. Mono and Stereo are now supported by a less expensive bundle. Surround and TDM have been put into a more expensive bundle with the add-on subtitle "XL".
burn em wrote: If that is the case does DP6.01 support AV5 which I think still had surround support in the non Protools HD/TDM version?
Good question.
I can't recall if the issue had more to do with Av5 not working on Intel-Macs, at least up to a certain version. I remember having to upgrade Altiverb so that I could use it on my MacPro. But I've not heard of problems *directly related to Av5* being used in DP6.x on PPCs.
Hopefully someone else will chime in to better answer this part of your question. You might want to drop a note to AudioEase about this. They may even have other information which would help you.
Finding a copy of Altiverb5 might be a little tricky, though.
