OMF Import problem!
Tesionman
OMF Import problem!
Post by Tesionman »
Hello!
I'm having a problem with importing OMF files(from Nuendo 3) in DP 6.01.
The same OMFs always open in DP 5.1 but in 6.01 it crashes(saying that DP quit unexpect...yada yada yada)..
Any help is appreciated!
Cheers
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
bradycline
Re: OMF Import problem!
Post by bradycline »
I was just about to ask about this as well.
I was trying to open an OMF file from Sonar (just a few simple audio tracks). No luck.
Interestingly though, it opened fine in Logic 8. From Logic I exported all tracks (which it automatically did from 0:00 :D ). This literally only took a few seconds. (Wow Logic is fast.) Then I dragged them into DP without problem.
Tesionman
Post by Tesionman »
bradycline wrote:I was just about to ask about this as well.
I tried in Logic but they don't open correctly(but doesnt crash).. In Dp 6 its the problem I mentioned and in DP 5.1 everything is in place(edits, etc...)!!
Wierd.
The Digital Era is great!!!...... when everything works. :roll:
Cheers
kassonica
Post by kassonica »
I've opened OMF's from logic seamlessly.
Jim
Post by Jim »
Attempting to open OMFs from FCP crashes 6.01 for me.
Hmm. This makes me think the problem may be with FCP, since some of you can get OMFs from Logic, etc.
musicarteca
Post by musicarteca »
Same for me, opening an OMF from FCP in DP6.01 always crashes. I have to import it in DP5.13, close the file and open it in DP6
Alex Rodriguez
Legato Productions
www.legatoproductions.com
martian
Post by martian »
same for me - ( protools session i was sent as an OMF last week )
actually I have had success with OMF from FCP... but sometimes it makes loads of bogus extra chunks
it would be good if they could get together a moderated known issues sheet for DP?
macpro 3 gig - 5 Gig RAM 10.6.3 Motu 2408 mk 2 Mackie HUI DP 7.21 intel imac 3 gig ram traveller OS 10.6.3
http://www.fork-media.com
Jim
Post by Jim »
musicarteca wrote:Same for me, opening an OMF from FCP in DP6.01 always crashes. I have to import it in DP5.13, close the file and open it in DP6
That may be an acceptable workaround. Do you have 513 and 601 installed on the same volume?
ttoeda
Post by ttoeda »
For me opening FCP OMF file opens except every stereo tracks changes to mono tracks. I was hoping XML thing works with DP6.01 but it always misses very first track(stereo). All other tracks opens(places) just fine.
tom t
musicarteca
Yes, I got DP 6 in a middle of a very big project, so I installed it and use it on the new ones, but continue to use 5.13 for the old project (a series). They are together in the same drive in perfect harmony. The only thing I have to remember is not to open an old project and save it in DP 6.01 (even that is not a major problem).
Alex Rodriguez
Legato Productions
