Playback buffer peaking.
wonder
Post by wonder »
I'm on Tiger and DP 5.13 on a quad core with 6.6 gigs of RAM. NOt a lot of edits at ALL. the playback buffer keeps peaking and tracks stop playing. My buffer is set to 1024.
PLEASE help. i have clients in and i can't get 15 seconds of playback before it starts dropping tracks. whats the deal? anyone know?
beppe
Re: Playback buffer peaking.
Post by beppe »
6.6 gb of ram? Sounds strange...
Are you sure?
Need more information.
For the setup you describe, that is entirely abnormal. Are there any background processes at work? Other applications open? Dashboard? How many tracks? How much automation? What plugins are involved? Are you running a lot of VI's?
In other words, review every possible thing that could be taking up CPU time and/or RAM space, and let's see what could be causing this.
vbassguy
Post by vbassguy »
ditto 6.6 gb ram sounds strange......
Is this apple ram? I have seen problems before caused by aftermarket ram.
G5 quad 2.5 ghz w/ 8 gigs ram, OS 10.5.4, DP 5.13,DP6, Mach 5,Mach 5 v2, SI, two loaded UAD-1e cards, PCIe 424, two Black Lion Modded 24 I/O's, Harrison 3624 console, cool old mics, pre's and compressors.....Great sounding Rooms.........
www.RRRPROD.com
wonder
Post by wonder »
Sorry ... 5.667 Gigs of RAM.
At any rate, there are NO other apps open. Dashboard has no widgets. NO background processing. I even MERGED all the existing tracks so there would be no edits/fades to compute.
I'm completely baffled cause my PPC G5 runs WAYYYY better than this performance. The CPU performance of the QUAD CORE isnt even at 25%, but the playback buffer will peak like heck!
any help?
wonder
Post by wonder »
wonder
Post by wonder »
I have the FW drive in the front FW buss. Could that be the issue? Are the rear busses faster?
burn em
Post by burn em »
Are all those tracks on a firewire drive? If so try moving the project to an internal dedicated audio drive.
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
wonder
Post by wonder »
thats never been an issue. I've had hundreds of projects with just as many or more tracks when using my PPC G5. This is supposed to a quad core an BLAZING fast. and its not ...
beppe
Post by beppe »
Wonder, the ram calculation is still strange!! 5.6 gb?
Please, open your system profiler and report the results at voice "memory";
perhaps your Mac have a problem on reading the dimms...
I tried Mac Pro 2.66 (now I have 2xquad 2.8ghz) and absolutely no problem whit projects more hard than in your snapshot...
You updated the driver of interface?
wonder
Post by wonder »
Here's the result of the VOICE MEMORY readout...
DIMM Riser A/DIMM 1:
Type: DDR2 FB-DIMM
Speed: 667 MHz
Status: OK
DIMM Riser A/DIMM 2:
Type: DDR2 FB-DIMM
Speed: 667 MHz
Status: OK
DIMM Riser A/DIMM 3:
Type: DDR2 FB-DIMM
Speed: 667 MHz
Status: OK
DIMM Riser A/DIMM 4:
Type: DDR2 FB-DIMM
Speed: 667 MHz
Status: OK
DIMM Riser B/DIMM 1:
Type: Empty
Speed: Empty
Status: Empty
DIMM Riser B/DIMM 2:
Type: Empty
Speed: Empty
Status: Empty
DIMM Riser B/DIMM 3:
Type: Empty
Speed: Empty
Status: Empty
DIMM Riser B/DIMM 4:
Type: Empty
Speed: Empty
Status: Empty
Maybe i read the ABOUT MY MAC wrong...
it reads 5Gb 667Mhz in the RAM section
Dave Bourke
Post by Dave Bourke »
You have 5 GB of RAM. The RAM speed is 667 MHz.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
kassonica
Post by kassonica »
How full is your FW drive?
Have you turned off warning when audio overloads processor and pre fill buffers?
I wonder if your FW drive could be fragged?
Very strange wonder
wonder
Post by wonder »
KASS....i thought of all that too ... the drive isnt close to being full. And doesnt OSX defrag drives automatically?
but heres the strange thing ... when I opened another song (with few tracks. not MANY fewer, but fewer nonetheless), the playback buffer was fine. But when i'm doing edits, comping, heavy resource stuff ... this computer is just not flexing its muscle! I tried deleting VI tracks to try and free up CPU.
I'm not sure what the heck is going on but why is my PPC G5 kicking this QuadCores AS*????
kassonica
Post by kassonica »
wonder wrote:KASS....i thought of all that too ... the drive isnt close to being full. And doesnt OSX defrag drives automatically?
Do you have anything else running on the FW buss?
I'd try running it off the internal Drive.
I know my pro tower doesn't like some FW drives (well one so far)
I have 2 drives in the tower and one setup for audio and it workin better than my Sarotech FW800 drive used to.
How many VI's are you running?
