MOTU DP and GURU. newb versus V. instruments/routing
Posted: Fri Sep 19, 2008 2:47 pm
by Chagos
hi all,
i was wondering if there was anyone else using a combination of DP with fxpansion's GURU.
i'm curious to see if there are any problems or suggestions with how to run GURU inside DP.
I'm having a decent time now with the recording side of DP, but this is my first foray into the virtual plug in fields of DP and i just want it to go smooth, because so far DP is working like a champ.
so if anyone has any hints, tips or warnings about these two together, please share.
thanks
Re: MOTU DP and GURU. newb versus V. instruments/routing
Posted: Sun Sep 21, 2008 7:40 am
by cpeiv
I use GURU inside DP 5.13. Never had any problems with installation or operation.
Posted: Sun Sep 21, 2008 1:24 pm
by BKK-OZ
You need to be careful of versions - Guru 1.5.12 will not work with DP 5.13 - but any version lower or higher (either DP 6+ or Guru+/-) should work OK. Ck out fxpansion's forums for the latest info, apparently they are working on a fix for DP 5.13 & Guru 1.5.12, but given that Guru apparently works in DP 6+, I gave up on waiting for this and have updated to DP 6.
There have been some issues with Guru & DP over the last couple of years, but Angus & Co @ fxpansion seem to be fairly well committed to helping customers, so FWIW, I think that they aren't a bad company to back.
Posted: Sun Sep 21, 2008 2:56 pm
by Chagos
thanks.
i got a stereo track of guru up and running as an instrument insert and all seems to be ok.
now if i can figure out how to get each guru channel on its separate track inside dp i'll be set.
