Arturia VI's broken
edledbury
Arturia VI's broken
Post by edledbury »
So I waited for 6.01 to appear before venturing into the world of DP 6. Should have waited longer... Both Arturia's CS80 and ARP2600 emulations suffer from the same GUI problems. Both produce audio fine, and will change presets, but freeze when any object in the GUI is moved. DP doesn't crash, and by hitting OK in the alert dialogue about a dozen times I can get back to where I was. Very frustrating. My Native Instruments stuff seems more stable, although in Kontakt 3 I can no longer drag instruments from the browser into the main window....
It's a shame that I'll have to return to the relative safety of 5.13. There are some nice things in the new version (although I share some of the reservations expressed many times here regarding the GUI) - proverb seems especially usable.
If anyone has any thoughts as to how I can use my Arturia plugs in 6.01 I'd love to hear them...
Ed
mhschmieder
Re: Arturia VI's broken
Post by mhschmieder »
Do you have other Arturia plugs as well?
For some reason, CS80 and ARP2600 stopped working for me in DP 5.13.
Around the same time, ones that hadn't worked before (such as Jupiter 8V and ninimoog V) suddenly started working :-).
I haven't tried any of the Arturia plugs in DP 6.01 yet. They're not a high priority at the moment, in current tracking sessions, but if you also own other Arturia plugs that are failing, I can try them out. I'm not going to bother with the two mentioned though, as they were failing already for me in DP 5.13.
Don't forget to check Arturia's site for updates, as they, like most vendors, don't inform the user base.
jloeb
Post by jloeb »
edledbury, what computer and OS version are you running?
