Sent a Tech Link to MOTU.
While I'm waiting for their response, I thought I'd ask the forum:
I've been working in 6.0 exclusively for a few weeks now.
I've noticed that simple audio edits - copy, paste, for example, take incredibly long. Sometimes over a minute just to copy a short 2 second mono soundfile and paste it somewhere later in the track. This is with no plugins instantiated and not much else happening in the file.
I've tried setting the "Studio/Configure Studio Settings/Prefill buffers for Quick Start" to off, as recommended elsewhere in the forum, but it doesn't seem to help much on my setup.
Does anyone know if there's some preference file I can trash that will improve performance, or some other fix that I can do on my end?
General Requests:
1. I wish we could still select non adjacent tracks for simultaneous editing in the Tracks window, as used to be possible in earlier versions. It's a lot of extra work to have to move non-adjacent tracks next to each other to be able to edit them together. Now, when we select non-adjacent tracks, all the tracks in between are also selected.
2. I wish we still had access to the "tool well" at the top right of the Control Panel, so we can select Sequence Editor, Quickscribe, Mixing Board, etc, without having to mouse to the Project menu...
Best,
--Mac Pro Intel 8 Cor (2007), 16GB Ram, Sys 10.4.11, Digital Performer 6.0, ProTools 003 Factory, DV Toolkit 2, PCI-E 424, 2408 Mk II, 2408 Mk III, optical in and out to Apogee AD-8000, Apogee DA16, 3 MTP AV USBs, MTP II, MidiExpress 128, 12 SampleCell cards on Nubus Mac, 2 GigaStudio PCs, Aardsync II word clock house sync, Mach V, Mach V 2, MSI, Vienna Ensemble (4 instances), VSL Special Edition Extended, SE Plus, Concert Guitar, Upright Bass, Stylus RMX, Atmosphere, Trilogy, Analog Factory, AVOX AT5, SoundSoap, SoundSoap Pro, Altiverb, Elektrik Piano, Canopus ADVC110...
DP 6.0 edits take long time - ideas?
- Mr_Clifford
Re: DP 6.0 edits take long time - ideas?
Command-Clickinstacue wrote: General Requests:
If you learn the key commands you'll find them way quicker than having to click on the control panel.2. I wish we still had access to the "tool well" at the top right of the Control Panel, so we can select Sequence Editor, Quickscribe, Mixing Board, etc, without having to mouse to the Project menu...
DP 9.52 Mac Pro 10.14.6 RME fireface800. Sibelius. Dorico 4
I'm not experiencing this. I just finished working on an hour and 33 minute project with 500 soundbites. Copy and paste worked fine. Very odd to hear that you are having a problem with that.
Are you REALLY zoomed in when doing the copy and paste? I found if I was zoomed in too much, DP ran HORRIBLY. I just got used to working a bit further out.
Glad to hear that you're not having this problem Grimepoch. I wouldn't think that MOTU would release a version that does this on purpose.
My edits take forever with no sequence editor window open...
Maybe there's some preference file or some other file that I should trash and then rebuild??
Still waiting for an answer from MOTU, maybe some of you can advise me?
