And if I shut off streaming, it stops popping. Just using a SPDIF to go in and out of the reverb. Either clock can be master, same issue. Changed cables, but not it, since it has to do with the streaming being on or off.
I will try malditoyanki trick of setting buffers to 128 and multiplier to 3
Hey that seemed to work. thanks to Malditoyanki. saved me a call to the teenagers at tech support.
Now if they would fix the g3 g#3 keys on the universal concert grand piano classical kit, both have pops on the initial strike. Also hear a pop on the b2 key I think. Hard to believe that the image disc went out with this issue.
Mach V pops on S/PDIF with streaming active
