Moving Back to 5.11 / MAS version?
JSmith1234567
Post by JSmith1234567 »
After an unsuccessful try @ DP 6, i am moving back to 5.11.
I did an uninstall of DP6.
I still have 5.11 on my computer, but it seems to be having some plug-in problems.
Do I need to reinstall 5 from the disk, or is it a problem with the version of MAS?
thanks!
zed
Re: Moving Back to 5.11 / MAS version?
Post by zed »
JSmith1234567 wrote:I did an uninstall of DP6.
Yikes. Since DP6 and DP5 seem to share some files, I would be uncomfortable uninstalling it. I am not surprised that you are having issues. You will probably need to reinstall from disk unless you backed up your preference files and stuff before installing DP6. If you did, then just drag those back into the right places.
The part that is most likely to be causing you plug-in problems is:
Hard drive > Library > Audio > Plug-Ins > MAS > MAS AudioUnit Support.bundle You may have deleted this when you uninstalled and maybe other files in that folder, as well.
