MW Leveler Response Knob?
- hammerman
Can anyone tell me exactly what this knob does? It seems to decrease the compression effect when turned up? I am loving the sound of this BTW. I think it may be the best plug MOTU has ever made
M2 Mac Studio Ultra - 64 GB RAM - Sequoia - DP 11
- mongoose
I believe it puts some kind of a filter on the compressor's (internal) sidechain, a HPF IIRC. This lets you focus on higher transients and not, say, squash an entire drum kit every time the kick rumbles. It's a really useful parameter.
If I have remembered this incorrectly (not at the studio machine right now), then my apologies.
Spankin' 2020 10-core iMac, 40GB, Catalina, DP 10, Ivory, B-5, M-Tron,
UAD-2, Wissner Artist Upright Grand, Tokai MAT Strat, P-Bass, and a bunch of other noisemakers.
On the rear panel of the original hardware LA2A, there is a machine screw. That machine screw is the Response control on our MW Leveler. Like everything else on the MW Leveler, the Response control is a faithful model of the parameter on the original hardware.
Input signal is sent to a detector circuit. The detector circuit controls the gain reduction circuit.
The LA2A was a funky bit of gear and those quirks are what makes up it's overall sound. One of those quirks is that the signal going to the detector circuit is not flat frequency response.
The set screw on the back of the original hardware and the Response control on the MW Leveler affect the frequency response of the signal that is sent to the detector circuit.
As you turn the knob from left to right, you are introducing a notch filter to the signal (that is triggering the detector circuit). The notch starts at around 4k and at the full right position is around 2k. As you sweep the knob from left to right, you increase and widen the notch, as well as lower the frequency of the notch.
What this means is that as you notch out 2-4k going into the detector circuit, the circuit responds less to those frequencies. The detector circuit become more sensitive to frequencies above and below the notch.
Examples:
Leveler is applied to snare. The wires of the the snare decay slower than the drum head response and at a higher frequency. Therefore with flat detector response, the Leveler continues to reduce gain based on the decay of the snare wires. If you pull down the Response, the detector circuit is less sensitive to the snare wires and more responsive to the drum head itself. You get faster and more accurate tracking of the overall snare drum.
A vocal track has sibilance and maybe some low frequency pops. However, the dominant frequencies of the vocal track are upper midrange, and the leveler is most responsive to the body of the vocal and less responsive to sibilance and the pops. By increasing the Response control, less of the body of the vocal is sent to the detector circuit and the detector becomes more sensitive to sibilance and pops. You get better control over sibilance and low frequency junk.
Ain't this stuff too cool?
Dave
Examples:
Dave
Man, that just makes me Dizzy!magicd wrote: Ain't this stuff too cool?
Dave
Ditto.hammerman wrote:Dave, you and MOTU are just too cool!
Thanks for the thorough explanation! I will copy and file that
Thanks Dave
iMac Pro 3 GHz 10-Core Xeon E5, 64GB ram OS X 10.15.7, UA Apollo 8 Quad + Satellite Quad, UA 2192, Waves V12, LASS Full, VSL, Korg MS-20, Elektron A4, Moog SlimPhatty, NI Komplete13, ROLI, Soundtoys 5, Arturia V Collection, GForce Oddity, Serum.
- Eleventh Hour Sound
I don't think it's far fetched to pay $200 for the Leveler. When you add in the Proverb, I think these two plug ins alone justify the cost of the upgrade for DP users...magicd wrote:On the rear panel of the original hardware LA2A, there is a machine screw. That machine screw is the Response control on our MW Leveler. Like everything else on the MW Leveler, the Response control is a faithful model of the parameter on the original hardware.
Examples:
Dave
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars
It rally is. I just have to learn the new interface. This old dog needs ot sit and RTFM - again!Tomrabbit wrote:
DP6 is working nicely here.
Dave, thanks for the information about the notch filter in the Leveler. It's great to get the inside story. I don't think that was in the manual, though the manual did say that you might get different results on different passes, which I thought was cool. I guess it depends on the speed of the return to normal.
Also, thanks for a job well-done in DP6. I've found only a few glitches, but have yet to determine whether they were yours or mine; very likely just mine. And yes, I think a lot of us probably are going to want to chat with you guys about the interface, but it's not bad, and 90% of it is fantastic. I like the look. The speed increase is amazing, too.
I'd sure like to know one thing: was this the big Cocoa rewrite?
