DP6 is not opening up!!!
shuld
Post by shuld »
Hello, Just installed DP6. Trying to open it up. Keeps crashing! Dont seem to know whats making it happen! Anyone?
Dave
DP 7.01, 2 x 2.66 GHz Dual-Core Intel Mac 4 GB ram ,Macbook 2.16 1.5 GB ram, Motu 896HD, Motu Ultralite, Powercore compact, , Reason 4.0, M-box, , MiniMonsta, UAD 2 QUAD, B4 2, Stylus RMX Guitar Rig 4,Battery 3, Universal Audio 6176, UA M-610, 2 Chandler Germanium and Germ Comp, Akg 414, Rode NT 1, Pearlman TM1, Royer 121, Cascade Fatheads 2,Rupert Neve Comp
Don T
Post by Don T »
All I can say is:
Permissions :-)
It's the ear, not the gear!
shuld
Post by shuld »
What is Permissions?
billf
Post by billf »
shuld wrote:What is Permissions?
See here:
http://support.apple.com/kb/HT1452
shuld
Post by shuld »
Already did repair permissions. Still not opening up!!! Wow!!! This is the first time I have had trouble with any of DP's installs!! I feel helpless!!!
shuld
Post by shuld »
Now DP 5.1.2 is not opening!! It seems like its reading all my plug ins. Then crashes! Is there a way to disable plugs?
FMiguelez
Post by FMiguelez »
What plug-ins do you have?
Have you been able to get past the point of AU examination, or is that when it crashes?
Eleventh Hour Sound
Post by Eleventh Hour Sound »
Trying taking out your plug ins to see if you can start up. Go to Library/Audio/PlugIns/Components and pull those bad boys out and put them on your desktop for now.
If you have Melodyne or an old version of T-Racks, that may be the problem.
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
kassonica
Post by kassonica »
What mac Operating system are you using?
Re: DP6 is not opening up!!!
shuld wrote:Hello, Just installed DP6. Trying to open it up. Keeps crashing! Dont seem to know whats making it happen! Anyone?
Dave
Same thing happened to me today. I repaired permissions and pulled all non-DP plug ins (including all AU, MAS, VST, etc., ) out of their folder and it started right up - as did DP 5.13 - which also refused to start after installing DP 6.
Apparently, both programs are using the same support program to examine plug-ins. In my case, it was the KontactPlayer2 plug-in. The old Garritan player doesn't work either and has the same results. Why DP doesn't simply say the plug-in didn't pass and mark it as bad (as in past versions) is unknown to me. But MOTU has their work cut out for them. I wish I was beta testing for them as I could report this easier that setting up a tech link. But I'm not.
Here's my Techlink info:
Installed DP 6 today. Crashed on startup. DP 5.13 also would not run after installing DP 6. Repaired permissions. Same. Removed all non MOTU plug-ins and added them one at a time to isolate the problem.
KontaktPlayer2 consistently crashes DP 6 and now DP 5.13 at startup. DP 5.13 always worked until today. Same true for GarrtianPersonalOrchestra Player (original).
And here's the solution (as posted earlier by blue and others):
Replace the MOTU AudioUnit Support.bundle (root/library/audio/plugins/MAS) with the one that DP 5.13 installed. Another Time Machine success story for me. If you didn't back it up, I am happy to send you a copy under the condition that MOTU sanctions the email. YOU will have to take of that. I am not opposed to posting a copy on my website, but again, ONLY if MOTU says it's OK and you will have to get the permission from them and have them contact me. I would hope that they would include that in an update soon for those who want to use previously compatible plugs.
shuld
Post by shuld »
I fixed the problem. I downloaded a freeware app called AudioUnit Manager. I select the plugs that I think that DP6 wont read. Presto!!! Opens up!!
billf
Post by billf »
shuld wrote:I fixed the problem. I downloaded a freeware app called AudioUnit Manager. I select the plugs that I think that DP6 wont read. Presto!!! Opens up!!
For the sake of documenting issues, which plugins were the problem children?
The problem child here is the MOTU AudioUnit Support.bundle (root/library/audio/plugins/MAS) as mentioned above and in many other threads.
WHAT WERE THEY THINKING? Oh yeah, they were thinking how cool the GUI was. NOT. Perhaps they were thinking they'd be greeted a liberators of the GUI? NOT NOT!
