Audio Engine has dropped samples
duncan
Post by duncan »
I never got this message with DP 4.61 in OS 10.3.9, but as soon as I upgraded to 10.4.11, every time I'm playing a session with more than around 20 tracks, the 'audio engine has dropped samples' box pops up sparodically. Sometimes this happens during recording. I don't lose anything, but it's freaky for the client when they hear the Apple warning sound in the middle of a take.
Any idea on how to get this to go away? My separate internal audio disk is usually around 3/4 full, but it was that way in OS 10.3.9 too, and I never had the problem in that configuration.
G5 dual with 4 gigs ram.
It occurs to me, the only other change in the system was a UAD card, installed around the same time as the OS upgrade, but I get the message even when no UAD plugins are in use. I wonder if it's the ilok's fault?
I also picked up Disk Warrior and ran it. It said it fixed a few things, but not enough, apparently.
I'd go back to 10.3.9 if it wasn't for some plugins that require 10.4.
"Give a man a fish and he will eat for a day. Teach a man to fish and he will wipe out an entire species."
Eleventh Hour Sound
Re: Audio Engine has dropped samples
Post by Eleventh Hour Sound »
duncan wrote:I never got this message with DP 4.61 in OS 10.3.9, but as soon as I upgraded to 10.4.11, every time I'm playing a session with more than around 20 tracks, the 'audio engine has dropped samples' box pops up sparodically. Sometimes this happens during recording. I don't lose anything, but it's freaky for the client when they hear the Apple warning sound in the middle of a take.
Try increasing your buffer size and see if that helps :)
DP11.1, 16" MacBookPro 2.3Ghz 8 Core i9's 32GB Ram 1TB SSD, (2) external 1TB Samsung SSD's , Steven Slate SSD 5.5 and Trigger Drums, ML-1 Mic and VSX Headphones, Omnisphere 2, Trilian, Ivory2, EW, MSI, MX-4, Philharmonik 2, Komplete, Reason, Live, Melodyne, IK Multi's Total Studio, ARC, T-RackS, SampleTron, AMG's KickA--Brass. and my beloved guitars :-)
pencilina
Post by pencilina »
maybe also try taking the UAD plug ins out of the equation and seeing what happens..??
duncan
Post by duncan »
It was probably the buffers, which were set at 512 for some strange reason. I had always assumed they were set at 1024, which was the case a while back. Could be last time I trashed the DP prefs to get my 2408 to work, the 512 buffers setting came back.
Thanks for the reminder.
