brand new out of the box 828 MK3 not recognized by my laptop
majdid
Post by majdid »
Just got a a brand new 828 mk3.i followed the steps in the manual and tought its going to be easy to set it up and get it running in few minutes, unfortunately that wasnt the case.
i am currently using a laptop. so the provided cable was useless, i then decided to get a 6pin- to 4 pin to coonect it with the laptop. then i installed the latest drivers from the motu web site (828mk3_106ud), and then connected it to the pc and turned it on... nothing, although you can hear that when you switch it off or on, the coputer is making a small sound as you would connect or disconnect a usb hard drive or switch on the wireless.
i think i tried all options, is there anything i missed? can the 6pin to 4 pin be the issue? if it's the case, how can i hook it up with my laptop?
ps: im using windows vista.
thankx a lot.
stephentayler
Post by stephentayler »
are you using the power supply? the 4 pin firewire cable does not provide power to the unit
kind regards
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
majdid
Post by majdid »
the unit is on and i can see options and stuff in the LCD. unit is powered using the 220v socket on the back.
CSprague
Post by CSprague »
When you loaded the latest drivers did you go through the process of updating the firmware on the mk3 unit afterwards?
majdid
Post by majdid »
no, i tried but nothing seemed to be connected.
one update: now i can see 3 or 4 devices in the windows hardware list, as motu audio, motu wave, motu gsif and motu MIDI. the problem is that none of the motu softwares works (cuemix, motu audio console...). they all say please check if your device is on and driver and blabla ...
majdid
Post by majdid »
got it working!!! ouf, tried another (older) laptop which is toshiba XP SP3, and it worked like a charm... it's either the HP firewire port or the vista that sux! thanks for your help.
CSprague
Post by CSprague »
Vista might sux, but mine is running fine so far with Vista Ultimate 64. I made sure I had a TI FW chipset. This audio device is going to take some time to get use to.
