problem selecting command in save window.
mike_o
Post by mike_o »
when I have a window that shows me save/do not save/cancel, like when you close a song, if I hit tab a little grey highlight appears around the second option, but the first option stays full grey, then when I hit enter it still selects the first option.
as in open a dp project, make a small change and the close the project, the window appears - hit tab, see the grey highlight appear around the second option, then hit enter, the first option is selected.
how do I choose the second option without using my mouse?
macpro 2x2.66 10GB ram osx 10.4.9
Mac Pro 2X Dual Core 2.66Ghz-10.4.9-7 GigRam-828MKII-MTPAV-Ultralight MK3-Digi Performer6.01-PeakPro5.1-Reason4-AbeltonLive6-Virus Rack(Red)-ReMOTE 25 & 37 SL-Nocturn-Stanton Dacratch-PluggoPack-DimensionLE W/EmuProteusPack-Sylenth1-Discovery MAC-MX4-Rapture-Alpha-Octopuss-Automat-Automat1-TALbassline-TALUno60
AlMacMeister
Post by AlMacMeister »
In OS X, whatever button is glowing/pulsing is activated by hitting Return. The Esc key is supposed to be for the button that represents the opposite action of the one that is glowing/pulsing; in this case the Cancel button. Cmd-d (Apple-d) is for Don't Save.
Hope that helps!
mike_o
Post by mike_o »
thank you, but I used a bad example, I just used the DP window as a general reference, your suggestion was not quite right.
I am specifically adding file extensions to a LARGE batch of samples that lost their extensions when I transferred them somehow, eliminate the extension from an audio sample, then try to add one.
no matter what key I hit, it will only activate the circled command of keep "---", or nothing at all?
I cannot press any key or combination of keys to select "use aiff", this is killing me, I have a ton of sample's to add aiff to before anything I have will read them, these are my old custom samples that were burned to a disc a few years ago :cry: .
how do I do this, its the only part I stop and grab a mouse for, scroll through folders using key, highlight and add extension using keys. then that window and I have to grab my mouse,It's getting really annoying.
also my mac keybord got killed and I am using a logitech, but it has no flaws with any program-
Can anyone do this, find the button for this command?
and pressing escape as suggested simply cancels.
Thank you for trying meister.
muzishun
Post by muzishun »
Hi mike_o;
I got it working this way....
First you must have Full keyboard access set to "All controls" in System Preferences/Keyboard & Mouse/Keyboard Shortcuts... at the bottom.
Now in a dialog box, you can Tab between the buttons and use the Space Bar to select the highlighted option (not the full highlight; the outlined one)
Hope this works for you.
Mike
DP 6.02 - OS 10.5.6, MacPro 2.26 Dual Quad - 12 Gb RAM // DP 5.11 - OS 10.4.11 , G5 dual 2G PPC // 4.5 GB RAM // 2408 mkIII and 2408 //assorted plugs and VIs//Radikal SAC 2.2//
AlMacMeister
Oh, you're trying to rename a large number of files in the Finder. A batch rename utility like Filewrangler will make this very simple:
http://software.christopherdrum.com/filewrangler
mike_o
Post by mike_o »
both you guys are just too cool, thank you very much.
