I'm stumped. I just got an 828Mk3, and everything is set up and installed correctly. Audition 3.0 is set to MOTU Audio ASIO. Everything appears to be fine.
CueMix FX is reading everything fine. Audacity will record using the wave drivers. Audition is recording only silence.
Any ideas?
ETA: FWIW, I'm running Vista64 Ultimate. Everything installed perfectly, with no issues other than the one above.
Edit2: Driver is 3.6.8.1133. Also, if I play something back through audition, it will come through the MOTU. No matter what input I select, it records silence.
I track, so I only use one or two inputs at a time (if I'm using more than one mic or mic + plugging in guitar). I've used both front-panel mic ins to no avail.
828Mk3 + Adobe Audition ASIO problem
