Optimisation of G5 Dual 1.8 PCIx for the passage to DP6??
p.pan
Post by p.pan »
Hi every body,
I would like to prepare the passage to DP6 on my machine.
Thanks for your advices.
And congratulation for the WONDERFULL forum.
MacPro 5.1 6-core 3.33GHz 16GB RAM.
Motu 2408MKI PCIe 424, with Focusrite octopre
Alphatrack.
DP7.24, SD2, Omnisphere 1, Komplete 7,Ethno.1.0.1,Styllus RMX 1.8
Frodo
Post by Frodo »
G5 Dual 1.8,3.5G Ram,
2x Hard Drive 150G,X.3.9,DP 4.61
828MKII,Uad 1, Powercore firewire,Alpha Track, Mach5 1.2,
Styllus RMX 1.5,Ethno.1.0
Make sure you read MOTU's *minimum* requirements as well as the *recommended* requirements once the DP6 system requirements are posted.
You may even want to contact MOTU directly for specific information on DP6 running in Panther with some of the older versions of their plugins.
While I don't see a problem at first glance, DP6 is very new and very different. Even with the latest everything, it's so hard to tell what the caveats will be, if any. I would just get a thumbs up from the source for the sake of confidence.
p.pan
Post by p.pan »
Thanks for your reply,
But I don`t want to run DP6 with Panther......
What I mean in my question (And also because my machine begining to be) I dont want when I oppen a old project in DP 6 with Tiger or Leopard
My G5 stuc
* Install leopard or tiger????
* HD systeme internal or external????
* I need more RAM????
I just want to prepare....
Alphatrack.
