Hi,
Does anybody know if any of the Machfive 2 plugins can run in 64 bit mode under Vista 64 bit version. I'm sure the Standalone and DXI plugin can only run as a 32 bit process as it is installed in the X86 program files folder but i'm not sure about the others such as VST.
The install program asks if you are running a 64 bit OS so there must be some significance to that.
Machfive 2 on PC 64 bit support
- beejeh
Regards.
Machfive 3.0.3, PC user;
Sequencer=Sonar Producer X1 expanded. Using ASIO drivers.
O/S=Windows 7 Ultimate 64 bit. CPU=Intel Q6600 Quad core 2.4GHz, Mobo=ASUS P5K Premium WIFI AP (Black Pearl), Graphics=GeForce 8800GTX, RAM=8 GByte, Music H/W=Motu 828mkII & MTP/AV + Creative Audigy 2 ZS Pro Platinum
Also Macbook Pro OSX 10.6.7 user with Logic 9.
- beejeh
Re: Machfive 2 on PC 64 bit support
They all run 32 bit.
Regards.
