Audio Desk suddenly doesn't work
I am using Audio Desk with Motu896 once in a while (with a Mac powerbook). Usually I have no problems, but yesterday it was a nightmare. Every time I was clicking on either play or record, the program "unexpectedly quit" and wanted to send a report to Apple. I tried all day long just about everything I could, inc. using with different computers, without success. Nothing has changed since my last time location-recording, so I can't imagine what happened to the system.
Any idea would be highly appreciated!
There are a number of things that can happen-- some of them:
1. The caches and virtual memory get overwhelmed after a while. Does a restart solve the problem?
2. Digital Performer (Audio Desk) Preferences often get corrupted. Trashing them is a MOTU-recommended remedy. The preference file will regenerate when DP (Audio Desk) is rebooted.
3. Not enough RAM. Large projects and/or projects that are run for many hours can wreak havoc on the memory over time for reasons stated in #1. These days, 4GB is not too much to ask in terms of software demands. It may, however, be too much to consider for certain hardware which cannot support 4GB RAM.
4. Was the project that was running significantly larger or more complex than other projects that did not cause the problem? Size of project could have an impact.
5. Further to point #4, were there particular plugins in the project in question which might not have been used in other projects which did not crash? One consideration is a poorly written plugin. Another consideration is a more CPU-intensive plugin. Both types can tip the scales in favor of an unexpected quit.
6. Firewire busses can easily get overwhelmed. Have you reset your 896? When the project crashed, was there an excessive amount of audio data being streamed at that particular point in the project? Can the problem be reproduced? If so, does the problem recur in the same place? Or are the crashes completely random?
7. What is your computer hardware? You mentioned a Powerbook and not a MacBook, so that implies a PPC processor.
8. What version of DP (Audio Desk) and what version of OSX are you using in combination?
9. Have you tried upgrading DP (Audio Desk) or OSX?
10. Have you installed a new version of QuickTime?
11. Have you installed the new Airport Update which is known to cause problems?
12. Were you editing on the fly when the crashes occurred? Editing on the fly is a general no-no. To edit, stop playback, edit, resume playback.
I don't think I've scratched the surface with the possible causes, but answering some of the questions will help find the needle in the haystack.
Thanks for the great list of possible causes!
Again, thanks!
Nandor
No.1. The caches and virtual memory get overwhelmed after a while. Does a restart solve the problem?
I'll try this!2. Digital Performer (Audio Desk) Preferences often get corrupted. Trashing them is a MOTU-recommended remedy. The preference file will regenerate when DP (Audio Desk) is rebooted.
I have 1GB RAM.3. Not enough RAM. Large projects and/or projects that are run for many hours can wreak havoc on the memory over time for reasons stated in #1. These days, 4GB is not too much to ask in terms of software demands. It may, however, be too much to consider for certain hardware which cannot support 4GB RAM.
Just started a new project, so the size was zero.4. Was the project that was running significantly larger or more complex than other projects that did not cause the problem? Size of project could have an impact.
No plugins at all.5. Further to point #4, were there particular plugins in the project in question which might not have been used in other projects which did not crash? One consideration is a poorly written plugin. Another consideration is a more CPU-intensive plugin. Both types can tip the scales in favor of an unexpected quit.
As I said, it was right at the start of a new project, and couldn't even start to record.6. Firewire busses can easily get overwhelmed. Have you reset your 896? When the project crashed, was there an excessive amount of audio data being streamed at that particular point in the project? Can the problem be reproduced? If so, does the problem recur in the same place? Or are the crashes completely random?
PPC.
Audio Desk 2 and OS 10.48. What version of DP (Audio Desk) and what version of OSX are you using in combination?
Yes but I didn't find one for Audio Desk. OS not, I have the latest, 10.4.119. Have you tried upgrading DP (Audio Desk) or OSX?
yes, the pro version10. Have you installed a new version of QuickTime?
probably; I install usually always when the updater tells me.11. Have you installed the new Airport Update which is known to cause problems?
Again, thanks!
Nandor
Does the problem occur right after a fresh boot-up of the computer?
Do a search in the Finder for all files that include "com.motu...". There's one file called "com.motu.DigitalPerformer.plist", but there may be others. The directory is: User Library> Preferences. Trash all of those files and try again.
If that doesn't do it...
Reinstall the same version of Audio Desk. If it worked before and suddenly stopped working, something somewhere got corrupted-- and it could be an invisible file which is difficult to remove manually. This won't erase your projects, but you may even want to use the disk to uninstall Audio Desk first.
There are all sorts of things that can be done with the Terminal, but Terminal is not the most intuitive utility in OSX.
However, if there has been an official crash, there will be an official crash log. In the Finder, search for Logs. If you find an Audio Desk crash log file, copy the whole thing into a post in this thread. I'm not fluent in hieroglyphics, but there may be clues I could pinpoint which may be the cause of the problem.
Failing all else, contact MOTU directly and make sure to stress that things were working just fine and suddenly stopped working. MOTU might comment on the fact that you have 1GB RAM, but while more RAM always helps, it doesn't explain why things suddenly stopped working when creating a new project.
I would definitely make a practice of saving the project and restarting at regular intervals throughout a single day. If you are doing live recording on location, restart the computer after the rehearsal and/or before the performance. The more often you do this, the more often OSX will dump useless processes that can clog the oh-so-mysterious world of virtual memory.
I tried all you were suggesting but unfortunatelly nothing helped...
here is the crash log:
Date/Time: 2008-04-18 10:17:29.362 +0200
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: AudioDesk
Path: /Applications/AudioDesk•„• 2.01.app/Contents/MacOS/AudioDesk
Parent: WindowServer [66]
Version: AudioDesk•„• 2.01 (1.0)
PID: 444
Thread: 7
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000014
Thread 0:
0 libSystem.B.dylib 0x9002c4b8 semaphore_wait_trap + 8
1 <<00000000>> 0x11f4b078 0 + 301248632
2 <<00000000>> 0x1302f658 0 + 318961240
3 <<00000000>> 0x12f933c8 0 + 318321608
4 <<00000000>> 0x000af730 0 + 718640
5 <<00000000>> 0x000af65c 0 + 718428
6 <<00000000>> 0x000af2d0 0 + 717520
7 <<00000000>> 0x000aef1c 0 + 716572
8 <<00000000>> 0x00007058 0 + 28760
9 <<00000000>> 0x0057a5b4 0 + 5744052
10 <<00000000>> 0x130044d0 0 + 318784720
11 <<00000000>> 0x130048dc 0 + 318785756
12 <<00000000>> 0x0061b6c8 0 + 6403784
13 <<00000000>> 0x004fd530 0 + 5231920
14 <<00000000>> 0x004fce44 0 + 5230148
15 com.apple.CoreFoundation 0x907f2370 __CFRunLoopDoTimer + 184
16 com.apple.CoreFoundation 0x907dece8 __CFRunLoopRun + 1680
17 com.apple.CoreFoundation 0x907de29c CFRunLoopRunSpecific + 268
18 com.apple.HIToolbox 0x932abb20 RunCurrentEventLoopInMode + 264
19 <<00000000>> 0x11f44d88 0 + 301223304
20 <<00000000>> 0x121071e0 0 + 303067616
21 <<00000000>> 0x12104f9c 0 + 303058844
22 <<00000000>> 0x11f27868 0 + 301103208
23 <<00000000>> 0x12104b74 0 + 303057780
24 <<00000000>> 0x121050ec 0 + 303059180
25 <<00000000>> 0x11f22c30 0 + 301083696
26 <<00000000>> 0x11f20d8c 0 + 301075852
27 <<00000000>> 0x000aac9c 0 + 699548
28 <<00000000>> 0x11f29914 0 + 301111572
29 <<00000000>> 0x00005608 0 + 22024
30 <<00000000>> 0x0000574c 0 + 22348
31 <<00000000>> 0x00005260 0 + 21088
32 <<00000000>> 0x00004be8 0 + 19432
33 <<00000000>> 0x00004a18 0 + 18968
Thread 1:
1 <<00000000>> 0x11f4b858 0 + 301250648
2 <<00000000>> 0x11f4b664 0 + 301250148
3 <<00000000>> 0x1302cee8 0 + 318951144
4 <<00000000>> 0x12ff8728 0 + 318736168
5 <<00000000>> 0x130dd4f4 0 + 319673588
6 <<00000000>> 0x1310e13c 0 + 319873340
7 <<00000000>> 0x11f4b43c 0 + 301249596
8 <<00000000>> 0x11f4b364 0 + 301249380
9 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000b29c mach_msg + 60
2 com.apple.audio.MIDI.CoreMIDI 0x9738fac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84
3 com.apple.audio.MIDI.CoreMIDI 0x97382c80 MIDIInPortThread::Run() + 64
4 com.apple.audio.MIDI.CoreMIDI 0x97386f44 XThread::RunHelper(void*) + 28
5 com.apple.audio.MIDI.CoreMIDI 0x9739087c CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 3:
2 com.apple.CoreFoundation 0x907de998 __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907de29c CFRunLoopRunSpecific + 268
4 com.apple.audio.CoreAudio 0x91459524 HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
Thread 4:
2 <<00000000>> 0x1197e64c 0 + 295167564
3 <<00000000>> 0x1197e5c8 0 + 295167432
4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 5:
1 <<00000000>> 0x11978b8c 0 + 295144332
2 <<00000000>> 0x11971970 0 + 295115120
3 <<00000000>> 0x11973198 0 + 295121304
Thread 6:
0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556
2 com.apple.audio.CoreAudio 0x9146a6ac CAGuard::WaitFor(unsigned long long) + 204
3 com.apple.audio.CoreAudio 0x9146a5bc CAGuard::WaitUntil(unsigned long long) + 304
4 com.apple.audio.CoreAudio 0x91468800 HP_IOThread::WorkLoop() + 852
5 com.apple.audio.CoreAudio 0x91468498 HP_IOThread::ThreadEntry(HP_IOThread*) + 16
6 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 7 Crashed:
0 <<00000000>> 0x13059f94 0 + 319135636
1 <<00000000>> 0x13059c60 0 + 319134816
2 <<00000000>> 0x12faf988 0 + 318437768
3 <<00000000>> 0x12faf188 0 + 318435720
4 <<00000000>> 0x1302d140 0 + 318951744
5 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 7 crashed with PPC Thread State 64:
srr0: 0x0000000013059f94 srr1: 0x000000000000f030 vrsave: 0x0000000000000000
cr: 0x22000002 xer: 0x0000000020000000 lr: 0x0000000013059c60 ctr: 0x000000000057b79c
r0: 0x0000000013174b4c r1: 0x00000000f0407b50 r2: 0x0000000000000000 r3: 0x0000000013174b40
r4: 0x0000000000000001 r5: 0x00000000d70a37d9 r6: 0x00000000f0407bf0 r7: 0x00000000f0407bf8
r8: 0x00000000f0407bf4 r9: 0x00000000a7e03ca4 r10: 0x0000000000000000 r11: 0x0000000011f6aff4
r12: 0x000000000057b79c r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
r16: 0x0000000000000000 r17: 0x0000000013174ad8 r18: 0x0000000013174b38 r19: 0x0000000000000000
r20: 0x000000009de4d719 r21: 0x0000000000bcea10 r22: 0x0000000000bceba8 r23: 0x0000000000bcebdc
r24: 0x0000000000000000 r25: 0x0000000000000000 r26: 0x0000000011f75188 r27: 0x00000000f0407bf0
r28: 0x00000000f0407bf8 r29: 0x00000000f0407bf4 r30: 0x0000000013174b38 r31: 0x0000000013174b68
Binary Images Description:
0xbb9000 - 0xbbbfff com.apple.textencoding.unicode 2.0 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1fcb000 - 0x1fccfff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x54e2000 - 0x551bfff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x5571000 - 0x558efff com.motu.driver.FWA.HALPlugin ??? (1.1) /System/Library/Extensions/MOTUFireWireAudio.kext/Contents/PlugIns/HALPlugin.bundle/Contents/MacOS/HALPlugin
0x55a4000 - 0x55e3fff com.apple.QuickTimeFireWireDV.component 7.4.5 (67) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x5622000 - 0x56b5fff com.MOTU.MAS.plugin.AutoPan AutoPan version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
0x56ec000 - 0x56f5fff com.MOTU.MAS.plugin.Reverse Reverse version 1.0.1, 8/10/03 (1.0.1) /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
0x5805000 - 0x5900fff com.MOTU.MAS.plugin.Auralizer Auralizer version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/Auralizer.bundle/Contents/MacOS/Auralizer
0x594b000 - 0x5994fff com.MOTU.MAS.plugin.Buffy Buffy version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/Buffy.bundle/Contents/MacOS/Buffy
0x59b3000 - 0x5a1efff com.MOTU.MAS.plugin.Chorus Chorus version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
0x5a4b000 - 0x5a83fff com.MOTU.MAS.plugin.DCNotch DC Notch version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
0x5a9b000 - 0x5b75fff com.MOTU.MAS.plugin.Delay Delay version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
0x5bbc000 - 0x5c33fff com.MOTU.MAS.plugin.Dynamics Dynamics version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
0x5c61000 - 0x5cc8fff com.MOTU.MAS.plugin.Echo Echo version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
0x5cf4000 - 0x5dd3fff com.MOTU.MAS.plugin.eVerb eVerb version 4.0.2 (4.0.3) /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
0x5e19000 - 0x5e90fff com.MOTU.MAS.plugin.Flanger Flanger version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
0x5ec1000 - 0x5ed3fff com.MOTU.MAS.plugin.InvertPhase InvertPhase version 1.0.1, 8/10/03 (1.0.1) /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
0x5ee1000 - 0x5f2cfff com.MOTU.MAS.plugin.MSDecoder MS Decoder version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
0x5f4b000 - 0x5fe9fff com.MOTU.MAS.plugin.MultiModeFilter Multimode Filter•„• version 2.0.2 (2.0.3) /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
0x602d000 - 0x60a1fff com.MOTU.MAS.plugin.Phaser Phaser version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
0x6205000 - 0x62b7fff com.MOTU.MAS.plugin.ParaEQ ParaEQ version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
0x62f6000 - 0x6374fff com.MOTU.MAS.plugin.Plate Plate version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
0x63a7000 - 0x643cfff com.MOTU.MAS.plugin.Preamp PreAmp-1 version 3.0.1 (3.0.3) /Library/Audio/Plug-Ins/MAS/PreAmp-1.bundle/Contents/MacOS/PreAmp-1
0x647d000 - 0x64cefff com.MOTU.MAS.plugin.QuanJr Quan Jr•„• version 2.0.1a2 (2.0.2) /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
0x64f1000 - 0x6541fff com.MOTU.MAS.plugin.Reverb Reverb version 3.0.1a2 (3.0.2) /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
0x6561000 - 0x65d7fff com.MOTU.MAS.plugin.RingMod Ring Modulator version 2.0.2 (2.0.3) /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
0x6609000 - 0x66bffff com.MOTU.MAS.plugin.SonicModulator Sonic Modulator version 3.0.2 (3.0.3) /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
0x6711000 - 0x677ffff com.MOTU.MAS.plugin.Tremolo Tremolo version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
0x67ae000 - 0x683ffff com.MOTU.MAS.plugin.Trim Trim version 4.0.1a2 (4.0.2) /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
0x7647000 - 0x76c0fff com.apple.applepixletvideo 1.2.5 (1.2d5) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x8eab3000 - 0x8eb83fff com.apple.QuickTimeMPEG4.component 7.4.5 (67) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x8ee59000 - 0x8ee5dfff com.apple.QuickTimeH264.component 7.4.5 (67) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x8f4f0000 - 0x8f4f5fff com.apple.CoreMediaAuthoringPrivate 1.3 /System/Library/PrivateFrameworks/CoreMediaAuthoringPrivate.framework/Versions/A/CoreMediaAuthoringPrivate
0x8f840000 - 0x8f86efff com.apple.CoreMediaPrivate 8.0 /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.10 (368.33) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aea000 - 0x90b5cfff IOKit /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.17 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f92000 - 0x90fd4fff com.apple.CFNetwork 129.22 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe9000 - 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91011000 - 0x91092fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d8000 - 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91112000 - 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib
0x91123000 - 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dd000 - 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ed000 - 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib
0x913f9000 - 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91434000 - 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91444000 - 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fc000 - 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fe000 - 0x91536fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91551000 - 0x91623fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91676000 - 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174e000 - 0x91805fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91842000 - 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918cf000 - 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91904000 - 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193c000 - 0x9197efff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9199a000 - 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bc000 - 0x91a02fff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a19000 - 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b2e000 - 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b48000 - 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6c000 - 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c72000 - 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c78000 - 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce7000 - 0x91d24fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91d2b000 - 0x91d45fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d4a000 - 0x91d4dfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d4f000 - 0x91e3dfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91e5c000 - 0x91e5cfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e5e000 - 0x91f43fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f4b000 - 0x91f6afff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fd6000 - 0x92044fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9204f000 - 0x920e4fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x920fe000 - 0x92686fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926b9000 - 0x929e4fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a14000 - 0x92b02fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b05000 - 0x92b8dfff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bce000 - 0x92df9fff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f26000 - 0x92f44fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f4f000 - 0x92fa9fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fc7000 - 0x92fc7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fc9000 - 0x92fddfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92ff5000 - 0x93005fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93011000 - 0x93026fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93038000 - 0x930bffff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930d3000 - 0x930defff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930e8000 - 0x93115fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9312f000 - 0x9313efff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9314a000 - 0x931b0fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931e1000 - 0x93230fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9325e000 - 0x9327bfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9328d000 - 0x9329afff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x932a3000 - 0x935b1fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93701000 - 0x9370dfff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x941f3000 - 0x942b8fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9430b000 - 0x9430bfff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9430d000 - 0x944cdfff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9455c000 - 0x945acfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945b5000 - 0x945cffff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x945e0000 - 0x94602fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x947a5000 - 0x947b4fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x947bc000 - 0x947c9fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9480f000 - 0x94828fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9482f000 - 0x94b59fff com.apple.QuickTime 7.4.5 (67) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94c40000 - 0x94cb1fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x97382000 - 0x973c1fff com.apple.audio.MIDI.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x977ad000 - 0x977ccfff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97fd2000 - 0x97fdffff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x99474000 - 0x9a284fff com.apple.QuickTimeComponents.component 7.4.5 (67) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
Report Version: 4
Command: AudioDesk
PID: 444
Thread: 7
Thread 0:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7 Crashed:
