Man, that discussion went so far over my head, I needed binoculars just to watch the realtime printout.
Actually, the UNIX E. problem started 6-8 months ago when my IR lib was tragically cut at least in half.
It just seemed to continue on from there when I bought the new Mac.
Dave Bourke wrote:Nicky, do you still have the original Mac from which you transferred all your stuff? How did you actually do the transfer to the new Mac?
I traded the old Mac in, and removed my audio drive onto which I copied everything I could think of.
I only received 1/2 an hour's notice that the boss of the business was on his way to pick the thing up.
I had only just started burning my first backup disc when this happened, so I frantically quit the process, made the copy I mentioned and removed the drive, ripped the PCI 424-X and TC cards out of the machine and packed it up whilst simultaneously dealing with an agitated neighbour who had arrived at the front door in a panic after two trees from my yard had fallen into his.
Given the mad rush and confusion, I was grateful to have even had a chance to make the quick copy I did.
Dave Bourke wrote: If you used a Firewire drive or Firewire Target mode to do it, I wouldn't worry about what the new Mac's Finder is showing you on those drives because it's using the faulty database to display the data (good grief, I'm going senile ••“ I can't remember the correct word for this).
You know now what I did, but I wonder if it could be that I technically haven't reformatted the drive?
I was thinking about this last night. Using DU, I had copied its contents and repartitioned (and erased) it before copying the data back to it.
The idea was to ensure maximal compatibility with Leopard as I'd noticed that it employs a new GUID scheme (whatever the heck that is).
This was the first thing I did with the new 'puter.
I can't help but wonder whether the erase and repartition didn't change the format as I'd hoped.
EDIT: I just fired DU up and checked - all Mac OS Extended Journalled.
Dave Bourke wrote:Did you try trashing the Finder .plist and restarting? That can sort out quite a lot of squirrelly stuff. Also, a PRAM reset might be an idea.
I'm using 3 different partitions (OS installs) across 2 drives as I wrestle with this, so much restarting has been done.
Dave Bourke wrote: Failing that, incense, bonfire, bodypaint, chicken, very sharp knife.
Kind regards.
What? How will eating dinner help?
